Constant disconnects and speed drops
MikeC78
Message 18 of 18
Hi, for the last few days my connection has been randomly dropping out, usually it is rock solid.
I tried contacting live chat but they were awful with the cut and paste answers and went around in circles.
There was nothing wrong with my original wiring, but regardless for the sake of time I went out and bought a new set of wires and filter. I plugged it directly in to the connection behind the face plate (I will add picture to the bottom) it worked straight away but not at full speed (usually 80/20) but it has dropped again to 60/15
I have run line checks but it says there is nothing wrong, so it's either the face plate or the router itself (the posher looking one)
I come here as live chat is usually very helpful but I've not had to use them in a long time and, things have changed shall I say.
17 REPLIES 17
Message 1 of 18
Hi Mike
Ok no problem.
Message 2 of 18
Hi, that would be the next logical step, I don't know what days I will be free next week yet, can I reply on monday when I know what days will be free.
Thanks, Mike
Message 3 of 18
Hi Mike
Would you like me to arrange an engineer visit so they can investigate the fault detected on the line tests?
Message 4 of 18
Hi, the upstream speeds are normal now, but the download speeds have not returned to normal. The line has been connected now for just over two days, I have also had intermittent problems with the wifi with devices in the house so I don't know if it is faulty some how, I also ran a line test on the TT website and it shows a fault, but apart from the slower download speeds the line is fine.
Message 5 of 18
Hi Mike
Thanks for confirming, the last speed test you completed, was this a wired test?
Message 6 of 18
Yes it was off for nearly 2 hours while I went shopping. When I came back  and powered it back it back on, it connected at 60/15, then as above while I was up it disconnected and reconnected at 80/20 but the speed was still the same as 60/15.
Message 7 of 18
Hi Mike
Did you do the 30 minute power down of the router?
Message 8 of 18
Hi, the connection seems fine, I was up when the DLM reset (about 4.30am) to normal speeds (router says connected at 79999/20000)
Usual download speeds are maxed at 9.8mb/s but are currently maxing at 7.2mb/s Line is fine just the speed hasn't reverted back to normal speeds.
speedtest result for quickness
https://www.speedtest.net/result/12308766649
Thanks, Mike
Message 9 of 18
Hi Mike
Sorry for the delay.
I've checked the connection stats again and the line is in sync at 76.6mb but the line test is detecting a potential fault.
Openreach are requesting that we arrange an engineer visit.
What wired speeds are you receiving this morning?
Message 10 of 18
Hi, my DLM has reset itself to 80/20 now, But I am still only getting speeds of 60/15. Is there something that can be done or just another waiting game?
Thanks, Mike
Message 11 of 18
Hi MikeC78
Yes we used to be able to change profiles for ADSL connections but that is managed by DLM too now.
I will check again in 48hrs to see how the connection is and if DLM has made any changes.
Message 12 of 18
OK i'll power it down need to go out soon anyway so won't be sat in the dark! Must of been the old broadband when you could reset profiles.
thanks
Message 13 of 18
Hi MikeC78
Thanks for your reply. Hopefully the connection will continue to remain stable.
We can't reset the profile, this is managed by Openreach's DLM. It may be worth powering down the router for a full 30 minutes and then leaving the router switched on without rebooting whilst DLM is monitoring/adjusting the profile.
Message 14 of 18
Hi, and thanks for getting back, it seems to have settled down now been connected for a day and a half, could please reset my profile back to 80/20 if that's possible and see how that goes.
Message 15 of 18
Hi MikeC78
I've completed a line test which hasn't detected any faults but I can see re connections on the line.
If you have recently tested with a different router at the test socket then the next step will be to arrange an Openreach engineer visit.
Message 16 of 18
72mb is the speed guaranteed speed and i've been connected. I had the exact same problem a few years ago, since it was fixed back then i've been connected for the last 3 years at 79999/19999. I also think my noise margin is somewhat high, it's been a while since I've had to deal with something like this so minds a little fuzzy on things.
Post from 3 years ago with the exact same thing:
https://community.talktalk.co.uk/t5/Product-Archive/Speed-drops/td-p/2283720
router stats:
Gliwmaeden2
Message 17 of 18
It's helpful to let us know what the minimum guaranteed speed is supposed to be for your line, and see the graph in Speed Centre in "find out more" about your router.
Also, leave it in the test socket now for staff to test - they sometimes come on 6am, but won't be back before Monday.
