Constant dropping of connection, worse than ever
KaleDeane
Message 13 of 13
My connection routinely drops at least once a day, usually around midnight, and has done for a while. The last couple of days it's not been coming back on for an hour or two afterwards. I'm in the test socket, I've used two different Talktalk routers, new microfilters and everything else I can think of. According to the last time I posted, there's no faults in the line.
I'm not going to keep paying £30 a month for a service that doesn't work when there are so many better alternatives. I'll chat to Talktalk directly when I can tomorrow but for now, if anyone has any ideas please let me know.
12 REPLIES 12
Message 1 of 13
Unfortunately I don't think we can do much at the moment but once the Covid restrictions are lifted we will be able to arrange an engineer visit to investigate
Message 2 of 13
It's not been dropping nearly as much, but it's still very unstable. For context, I use Google Stadia, which the connection is absolutely capable of (it only uses around 20mbps down) and I'm getting wildly varied quality due to packet loss, even on wired. It performs like there's a fault on the line, but apparently there's none detected?
I understand the Covid restrictions though, so I don't know what else you can do?
Message 3 of 13
Hi Kale,
How has it been since your last post?
If the connection is still dropping then we would usually arrange an engineer visit but we aren't able to do this at the moment due to Covid restrictions.
Message 4 of 13
So from when I posted this until tonight (18th Jan) I had no disconnections at all, now I've had two in one night.
I'm sure it's a coincidence, but every time I complain it gets better for about a week...
Message 5 of 13
The connection appears to have been stable over the last few days, have you notices any improvement?
Message 6 of 13
I don't have a phone to test that with unfortunately!
Message 7 of 13
OK thanks. Are you experiencing any problems with your telephone service, any noise on the line?
Message 8 of 13
Yeah it's still in the test socket.
Message 9 of 13
Hi KaleDeane
The line tests have not detected any faults but I can see re connections on the line.
Is the router still connected at the test socket?
Message 10 of 13
Then it sounds like the router/broadband that is unstable. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Message 11 of 13
1. It's the Huawei DG8041W. Talktalk sent it to me after I made similar complaints with the old one, which I can't remember the model of.
2. The light flashes orange (I believe, I'll update when it happens later on if this is wrong) until I power cycle the router. This usually fixes the problem within 5 minutes but hasn't been the last few days. Even so, it shouldn't be happening daily, surely.
3. I don't currently have wired connections due to moving the router to the test socket. But when I had the PC wired in, it was the same problem and a general lack of stability for an ethernet connection.
Message 12 of 13
1. What make/model of router do you have (if this is a TalkTalk router, these details will be on a label on the rear or underside of it) and what firmware version is it running?
2. What is the exact status of the lights on the front of the router when this happens?
3. If you have any wired connections, are they affected in the same way as wireless ones?
