Critical Error Huawai router
Thickjedi
Message 5 of 5
We had fibre broadband installed a couple of weeks ago and everyday we notice the connection drops out at certain times I looked in the logs and it shows critical error I have attached today's logs.
Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-19T20:11:24.805Z
2021-09-20 04:02:46 [Error][Alarm-Log] AlarmID:303500,AlarmLevel:Error,DoS attack. Type: smurf. Source IP address: 192.168.1.32. Destination IP address: 203.119.201.255. Source MAC address: 50-c7-bf-12-4f-7b
2021-09-20 14:58:40 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Success,Type:Login,Username:admin
2021-09-20 15:00:36 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Success,Type:Add,LANDevice.LANHostConfigManagement.DHCPStaticAddress:1,Yiaddr:192.168.1.20,Chaddr:ac:9e:17:88:13:2d,Enable:1
2021-09-20 15:02:47 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Success,Type:Add,LANDevice.LANHostConfigManagement.DHCPStaticAddress:1,Yiaddr:192.168.1.25,Chaddr:50:c7:bf:12:4f:7b,Enable:1
2021-09-20 15:03:22 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset by the software, Terminal:WEB
2021-09-20 15:04:08 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-09-20 15:04:08+00:00 DST], uptime is [34s].
2021-09-20 15:04:37 [Critical][Config-Log] Terminal:ACS(92.29.163.109),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-09-20 15:04:41 [Critical][Config-Log] Terminal:ACS(92.29.163.109),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-20T14:04:41.439Z
2021-09-20 15:07:40 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Success,Type:Login,Username:admin
2021-09-20 15:10:25 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Fail,Type:Login,Username:-
2021-09-20 15:10:30 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Fail,Type:Login,Username:-
2021-09-20 15:10:37 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Fail,Type:Login,Username:-
2021-09-20 15:10:37 [Error][Alarm-Log] AlarmID:104032,AlarmLevel:Error,Administrator exceeded maximum number of attempted logins.Terminal:WEB
2021-09-20 15:11:37 [Error][Alarm-Log] AlarmID:104519,AlarmLevel:Error,[WEB]unlocked!
2021-09-20 15:12:45 [Critical][Config-Log] Terminal:WEB(192.168.1.46),Result:Success,Type:Logout,Username:admin
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
2021-09-20 19:22:03 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-09-20 19:22:03+00:00 DST], uptime is [105s].
2021-09-20 19:22:04 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-09-20 19:22:08 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-20T18:22:08.564Z
2021-09-20 20:10:05 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-09-20 20:10:05+00:00 DST], uptime is [91s].
2021-09-20 20:10:05 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-09-20 20:10:10 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-20T19:10:09.880Z
2021-09-20 20:26:19 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-09-20 20:26:19+00:00 DST], uptime is [92s].
2021-09-20 20:26:20 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-09-20 20:26:25 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-20T19:26:25.233Z
2021-09-20 20:29:01 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-09-20 20:29:01+00:00 DST], uptime is [38s].
2021-09-20 20:29:27 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-09-20 20:29:30 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-20T19:29:30.541Z
2021-09-20 20:31:54 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-09-20 20:31:54+00:00 DST], uptime is [39s].
2021-09-20 20:32:18 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-09-20 20:32:22 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-09-20T19:32:21.914Z
2021-09-20 20:43:57 [Critical][Config-Log] Terminal:WEB(192.168.1.12),Result:Success,Type:Login,Username:admin
Paul
4 REPLIES 4
Message 1 of 5
Ok thanks for confirming. I'd recommend contacting our Future Fibre Team directly via Live Chat and they will be able to look into this further for you.
Your Future Fibre Support Hub
Message 2 of 5
Hi Debbie I don't have a landline due to me being on the broadband only package, it shows fttp***** in my account under telephone no.
Paul
Message 3 of 5
Hi Thickjedi
Please can you add your TalkTalk landline number to your Community Profile, we can then look into this for you.
Skynet_TX
Message 4 of 5
Hi @Thickjedi,
The 'kernel panic' entries shown in your log are a known problem, presumably your router is currently running firmware version 1.05.
The staff here will be able to push firmware version 1.06 to your router, this new firmware version is designed to resolve this known 'kernel panic' issue.
