on 07-01-2022 01:51 PM
I've been happy with this router for the last year or so, connection has been pretty solid on the fibre35 service.
However recently, the download speed has been dropping way BELOW the upload speed (which remains constant)!
I notice browsing is slow, then check with speedtest and this confirms the issue.
Upon restart of the router, everything is fine for a few more days.
I tried powering off the router for an hour, which i read somewhere on the forum once, but this hasn't resolved the recurring issue unfortunately.
Here's one example:
and after restart:
And again today:
and after a restart:
on 28-01-2022 03:11 PM
Hi sbutcher,
I've ordered the router, it should be with you within a couple or working days
on 28-01-2022 02:40 PM
thanks for the reply. having also read https://community.talktalk.co.uk/t5/Fibre/Throughput-speed-problem-with-my-DG8041W/td-p/2726681 who described a very similar problem , and lack of any other ideas, i think i should try the sagemcom router please.
on 28-01-2022 12:04 PM
Ok thanks for confirming. As the line test is clear and the sync speed looks consistent, would you like to try the Sagemcom router first?
on 28-01-2022 11:55 AM
previous router was the same as the replacement i have just been sent. had been consistently a very stable connection until the last few weeks.
on 28-01-2022 11:49 AM
Can I just confirm, was the previous router a Sagemcom or the same router as the one you have now?
on 28-01-2022 09:44 AM
this affects wired and wireless (screenshot from my earlier post was a wired connection plugged directly to the router, with wifi disabled). also i use 5ghz wifi which is not congested. also i remedy the throughput issue by restarting DSL only.
on 28-01-2022 09:21 AM
Hi sbutcher,
Line check is showing that all wifi channels are congested which would explain the drop in wifi speed, but it doesn't explain the drop in wired speed. Is there no difference between wired and wireless speeds?
on 28-01-2022 09:04 AM
hi, its the throughput speed that drops.
it's doing it again today - i've left the router alone and haven't restarted DSL as requested for troubleshooting
tested on wired and wireless today.
on 25-01-2022 09:26 AM
Can I just confirm, do you know if it's the sync or throughput speed which drops? Would it be possible to post back here the next time this happens before you reboot the router so we can check the connection stats please?
on 25-01-2022 09:18 AM
I just had to restart the DSL again this morning. The download speed returns to 35MB and stays constant for the whole day long (maybe for 1-5 days) and then drops again to either 20Mb, usually 10mb or much less. The upload speed stays constant, around 8-9mb even when the download speed is bad..
I usually discover it in the morning when i start work from home, and realise the internet is really sluggish.
The remedy each time is to restart the DSL from the DSL information page - don't need to restart the router.
I've had a new router sent and that didn't change things. I've had this line for years and haven't experienced this before now - perhaps a line quality problem? Not sure what could be causing this to degrade over a few days.
on 18-01-2022 02:54 PM
OK thanks. Could you run some speed tests at different times of day on the My Account speed checker and let us know when you've done this
18-01-2022 09:24 AM - edited 18-01-2022 09:36 AM
It happens on wifi and wired. Even after a restart yesterday, the download rate from had dropped today again (it was highly variable today, from around 1mb to 20mb). Clicking "restart DSL" resolved it as usual and i'm back to solid 35mb+ for the time being. Which also supports the idea that wired/wireless are both affected, since restarting the DSL doesn't reboot the whole router, and fixes the issue for a day or so.
on 18-01-2022 08:19 AM
Your line test is passing and router is in sync at 39.9Mbps. Do you experience the drop in speed on both devices connected to your router by Ethernet cable and wi-fi?
on 17-01-2022 10:44 AM
Hello
Even with the new router, i've noticed a slowdown after a few days
After a restart of the DSL , the download speeds are back up to high 35-40Mb again.
on 07-01-2022 03:17 PM
I've ordered the router, it should be with you within a couple of working days
on 07-01-2022 02:54 PM
hi debbie
sounds great, thanks.
on 07-01-2022 01:56 PM
Hi sbutcher
Would you like me to send a replacement router for testing to see how the connection/speed compares?
