on 19-01-2022 07:52 PM
HI Guys
I'm already on firmware 1.06t for kernel panic reasons. But am still suffering with wifi clients being kicked off, requiring a router restart.
Is this thing still the best router TT have? clearly unstable. Are there any old HG635 units in stock, that thing was flawless.
Cheers T
on 12-02-2022 12:15 AM
Hi @Stevechaz,
For the team here to look into your issue you would need to start your own topic on the community and explain exactly what problems you are having.
You will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow the team to identify you, and they will then be able to help.
Don't post any personal details in your new topic, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
The staff here probably won't be around now until Monday, but they should be able to respond early next week to help.
on 11-02-2022 10:35 PM
Hi Service team can i have a new router as this system is crap
Steve
on 11-02-2022 10:34 PM
I have had so many problems with the super fast BB it keeps dropping out and this causing so many problems with my Hive central heating controls too .why does this keep happening
on 11-02-2022 09:13 PM
Hi Support guys
All 2.4Ghz clients dropped off the network this evening again. (DG8041W running 1.06)
If I try the sagemcom again, and we have the same issue, and TT dont have any other router option, where does that leave customers? Do you help pay for a 3rd party solution?
KR T
on 21-01-2022 11:57 AM
Yes, that can be the case, but if you are switching between two modern routers that use the same type of encryption you can often get away with it and it will just work.
So it will often work if you are switching between two modern routers, but it can be an issue if you are switching from an older model of router to a modern router. So might be worth a try !
on 21-01-2022 11:52 AM
Hi Skynet, thanks I believe I've tried that before and have been unsuccessful. Is it as simple as that? Aren't there other factors at play MAC addresses and how the password is encrypted etc?
on 21-01-2022 11:22 AM
@ttbub You could always update the SSID and Password on the new router you receive, to match the SSID and password of the router you are currently using, then in theory all of our devices will just connect to your new router without you having to reconfigure them.
on 21-01-2022 11:15 AM
I'm not sure which firmware your Sagemcom currently has but I think it's likely to have an older version than the current version. As far as I'm aware later firmware versions don't specifically address wi-fi connectivity so I can understand it if you don't want to swap routers and change everything over.
on 21-01-2022 10:20 AM
Hi Chris, thanks it's very disruptive to swap routers about and reconfigure about 30 devices as you can appreciate. What's the latest firmware and has it been designed to improve wifi stability? there's no point if that has never been a factor in subsequent releases. If you don't know the answer or haven't got a change log that's a bit worrying too as it would be really helpful for you guys and the efficiency of this whole process to have transparency.
Kr T
on 21-01-2022 09:51 AM
In that case it's likely to have an older firmware version so we could try a more recent version. Please let me know if you'd like to try this
on 21-01-2022 09:43 AM
Hi Chris
Here's my last post about the sagemcom unit - https://community.talktalk.co.uk/t5/Fibre/Sagemcom-wifi-clients-dopping-please-also-run-a-line-test/... So whatever firmware it was back then.
kr T
on 21-01-2022 07:49 AM
OK thanks. Do you know which firmware version the Sagemcom currently has?
on 20-01-2022 02:54 PM
It just started being really flaky, then didn't work ultimately. It's been recycled now.
on 20-01-2022 02:42 PM
Could I just ask what happened to the HG635, do you still have it?
on 20-01-2022 02:16 PM
Hi Chris, yes I've done that for years, my benchmark for this stuff as I say, is the HG635 router you used to provide (versus the hg633 which did!). That never dropped clients and I expect has a much slower cpu and so on.
kr T
on 20-01-2022 01:26 PM
Hi ttbub,
Sounds like it could be wifi congestion if you're experiencing the same issue with 2 different makes and models of router, have you tried using a wi-fi analyser to check for the least congested wi-fi channel?
on 20-01-2022 01:04 PM
HI Michelle
EG multiple wifi clients, suddently having no connection. including phone, light bulbs, cameras. Some stay, some get booted off..
kr T
on 20-01-2022 12:06 PM
Apologies for the confusion, can I just confirm, what specific issue you are experiencing the Huawei Wifi Hub please? I wasn't sure what you mean by clients being kicked off?
on 20-01-2022 10:56 AM
Hi Michelle - dropping wifi - https://community.talktalk.co.uk/t5/Fibre/Sagem-FAST5364-newest-firmware-kicked-off-nearly-all-wifi/...3
even with the "wifi optimisation" turned off
kr T
on 20-01-2022 10:52 AM
Did you also experience dropping wireless with the Huawei Wifi Hub or was this a different issue?
