DHCP not functioning correctly
Alchall
Message 9 of 9
I am trying to use my ASUS CT8 router with my new future fibre 500 service.
Initially it worked but I now cannot get a connection, the router says that DHCP is not functioning correctly.
I have set VLAN to 101 and priority 0 as directed by the info here.
I can connect when I revert to the TalkTalk supplied hub so there’s clearly a connection but it seems like my service is locked to the talk talk hub and won’t supply an IP address to the Asus
8 REPLIES 8
Message 1 of 9
Hi Alchall,
Thanks for the update 🙂
Message 2 of 9
I have now resolved this.
I decided to start again, ignoring the fact that TalkTalk's instructions say to set VLAN to 101 etc. I let the router go through it's standard setup routine without applying any specific settings and it worked, I'm now up and running...
Message 3 of 9
Initially it worked, but when I switched to the talk talk hub temporarily and then switched back to the ASUS it will no longer connect.
I’ve done a full factory reset and set it up again from scratch but still no joy
Nrug0r
Message 4 of 9
Never had FTTP myself, though I wonder if you're using MPoA?
Message 5 of 9
Are you sure that this third party router is totally compatible with the TalkTalk service. This is a problem that I cannot help with, as I do not have one of these.
Message 6 of 9
Bump
Any ideas?
Message 7 of 9
There's no TalkTalk settings in the router but I have set it up according to the information in that link...
Message 8 of 9
Does this router have a TalkTalk option to configure it by, otherwise, a lot of 3rd party routers do not request that the lease allocated to them by the network to be extended. This is a feature of the router, not the network, hence why your TalkTalk router works OK.
Have a look at this page:-
Set up a non-TalkTalk router - TalkTalk Help & Support
