DISABLE UPNP
begnpitch
Message 7 of 7
I am trying to fix my "NAT Type" for Xbox Live and all the support pages and forums say I need to disable UPnP on my router, restart the router and then re-enable UPnP.
I thought UPnP was a standard setting on all routers but for some reason it appears it is hidden on my Talk Talk Hub (simplification gone crazy).
I have found some other forum threads where the TalkTalk support people have disabled this from their end.
Please can I ask that someone disables this for me on my router? I have updated all the profile pages so you can find my account.
I will need it re-enabled once I have restarted the router.
Let me know if you need anything else from me.
Many Thanks.
6 REPLIES 6
Message 1 of 7
Thank you, Will wait for the update
Message 2 of 7
Thank you, currently, you can't disable UPnP yourself with that firmware. You need to be on firmware V130 to be able to do this.
Although some people are running this firmware, there has been a pause in its rollout due to a problem that has been found in it. Once corrected the rollout will recommence.
Message 3 of 7
TalkTalk Wi-Fi Hub
version SG4K10002816t
Message 4 of 7
I am still waiting for you to tell me which WiFi Hub do you have, only then can I answer your question as they are both different to configure.
Message 5 of 7
Is there any news on disabling the UPnP in router settings, I need to disable it for security reasons as my computer network was attacked using this protocol.
Message 6 of 7
Which WiFi Hub do you have, is it the Sagemcom or the Huawei? The Huawei allows you to disable it yourself, the Sagemcom will also do, but not until the firmware is updated to a minimum of V130. There is a rollout of this firmware going on currently.
