Deactivate WIFI on eero Router
ChristianOBrien60
Message 3 of 3
I've just had fibre installed & have an eero 6 router, I would like to deactivate the WIFI as I have a smart home system, I've tried connecting with the router via my computer but it won't let me connect.
Message 1 of 3
Where you can't connect some smart devices, this may be down to the smart device being on the 2.4GHz band and the device running it's app is on the 5GHz band. There is no IP networking reason to block traffic between bands (unless "AP Isolation" is enabled). The only reason this happens that I know of is an app that has a bug in it. The only workaround to this is to rename each band's SSID (network name) different to each other. E.G add 5G to the 5Ghz band's SSID. Then if you connect the device with the app on to the same band as the smart device (usually the 2.4GHz band), it should work.
However, not having an Eero I have no idea how you do this, other than go into the Eero's app & look under Settings.
Message 2 of 3
Try the Eero app and see if this can be done from there.
