Devices Wifi connection dropping
AdamMori
Message 17 of 17
I have been having a problem for the last few months with the devices internet connection dropping. It is usually only 1-2 devices but can be all internet connections and it forces me to reset the router to fix it. The device still shows as connected to wifi, it just stops working. Sometimes there is an error about DLS. Any advice to fix this would be appreciated.
Adam Mori
16 REPLIES 16
Message 1 of 17
Hi AdamMori
We need the landline number so we can locate the line details.
I've ordered you a different make and model of router for testing, please allow 24-48hrs for this to arrive.
Message 2 of 17
I think I have now done this - not sure why it was needed, phone isn't even plugged in.
Almost a month with no solution so far.
Adam Mori
Message 3 of 17
Hi Adam
Please can you also add your TalkTalk landline number to your Community Profile.
Message 4 of 17
Hi Debbie - all done.
Adam Mori
Message 5 of 17
Hi AdamMori
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 17
Hi @star8shine7 @J0hn15
Please stop posting on this thread, it has nothing to do with you and all you are doing is getting in the way of the OP who created this report, getting a resolution.
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
Message 7 of 17
I know, I'm waiting for the manager to call me back right now. They promised today by 3. I've just called them, they apparently "can't transfer me to the manager, the manager has to call me back" They've just promised the manager would call me back by 6. I'm still waiting.
Message 8 of 17
glad its not just me then just great customer services don't all business record phone calls for training and monitoring purposes?
Message 9 of 17
They hung up on the phone to me yesterday too. We called them back for them to tell us the problem was on our end.
Message 10 of 17
so if this is a common fault and people are having issues surely TT should be working on this and not hanging up on the phones to customers? like they did to me so if im correct TT are breaching there contract as they are not supplying goods described in the contract?
Message 11 of 17
Hi @KeithFrench, I do currently have a problem. I've yet to have a resolution.
This is a known fault with TalkTalk SageMcom routers. Just looking at your activity, you also know this is a problem as many of your 'resolutions' are resolved by a new router. As is every post that I've seen on here over the past few days.
By having this 'complaints' forum open to the public it is easy to see that this is a wide spread problem with the SageMcom routers that TalkTalk has and that they have software, on by default, that makes these connections worse. This is not OK and as such my comment is valid and accurate.
The problem is not to do with the WiFi it is to do with the DHCP leasing and not correctly re-establishing the address correctly. (If you copy and amend openWRT, you can also have the same bugs in that version)
WiFi congestion can be bad, but a solution is to not have the 2.4GHz and 5GHz network names the same as this causes even more DHCP errors when the router incorrectly hands off from one network to the next. It would be good if TalkTalk enabled different SSID's by default, but they don't. Also any changes you suggest will be changed automatically when the SageMcom router upgrades as TalkTalk seems to restore these routers to factory settings. When they push updates.
This forum is full of public complaints and the people with resolutions are members of the public who are not employed by TalkTalk. This is appalling customer service. With no quality control: Take for example your pinned post at the top stating that "iOS warning about insecure networks is not that big of a deal" it might read easy but the quality control should be a lot higher. This directly goes against peoples best interests. If it wasn't that big of a deal, the richest company in the world wouldn't highlight it by building it into their operating system.
As for forums that aren't all complaints. YouTube comments, LinusTechTips and literally any other forum on the internet that isn't solely used to funnel customer complaints away from the "qualified and trained team" to the Wild West of advice from "blokes down the street".
Message 12 of 17
Hi @star8shine7
Do you have a current problem, if so, do you have a thread open for it, then someone might be able to help you.
I must beg to differ with your frustrations that "this is apparently a known fault with TalkTalk routers."
It is a known problem with the popularity of broadband & most 2.4GHz bands are getting totally unusable, due to congestion from other networks in the local area in question. Any make of router does not perform well in this band, where it is so oversubscribed. This is something that I do try to resolve wherever possible for any customer.
I do agree with you that the forum is full of complaints. I have yet to see a forum like this be full of people with no problems whatsoever. Not many people can be bothered to create a thread to say they have no problems. I think that you will find that for each complaint there are far more people who do not have an issue.
star8shine7
Message 13 of 17
This is apparently a known fault with TalkTalk routers. The "service" that they offer seems to be to send you a cheaper router that does not work with your only option to create a separate account on this forum to ask for help. There response will be to ask you to do lots of checks before telling you that there is a better router (that supposedly isn't broken out of the box), made by Huawei. This entire forum is full of more than 116,000 complaints just like yours and mine.
Message 14 of 17
In that case, I think the problem is WiFi interference.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 15 of 17
Sorry typo! DNS
Adam Mori
Message 16 of 17
Do you have a screenshot of this DLS error, I am not sure what that is?
