Devices losing connection to router
Pajspaj
Message 9 of 9
Recently both wired and wireless devices have started to lose connectivity to my WiFi hub. Usually only one or two devices are affected at the same time but occasionally it affects everything.
A reboot of the WiFi hub usually does the trick to restore but it is very frustrating and happening a few times a week.
I've tried spitting the WiFi into separate 2.4 and 5Ghz ssids, and also assigned all devices static addresses but no improvement.
If I wire up to the router and login whilst the issue is ongoing I cannot see anything immediately amiss.
My account is showing devices are having connectivity issues but advises it is unable to assist with individual devices.
Is it worth trying a different hub/router to rule this out?
8 REPLIES 8
Message 1 of 9
Thanks for the update and please let us know how the connection compares over the next few days 🙂
Pajspaj
Message 2 of 9
Hi Debbie, the new router is in, thank you.
We've had one blip yesterday so far but this looked to be the connection and not WiFi, so will continue to monitor.
Message 3 of 9
Hi Pajspaj
Apologies for this.
I have ordered the router, please allow 24-48hrs for this to arrive.
Pajspaj
Message 4 of 9
Good morning,
A few devices have dropped overnight so yes let's go ahead with a replacement router, as the front LED hasn't changed.
Do you need my address or can you get it from my profile?
Message 5 of 9
Hi Pajspaj
I've completed a line test which hasn't detected any faults. Would you like me to send a different router for testing to see how the connection compares?
Skynet_TX
Message 6 of 9
Ok, would be interesting to see what the LED does next time it happens, if it flashes amber / white then that would indicate the router itself is losing connection with the internet and is having to reconnect. If the LED remains solid white then the router is staying connected fine and it is possible you may be suffering from this known DNS issue.
Staff here will be able to help more tomorrow, they may be able to see if your router has been losing connection or not.
Message 7 of 9
Thanks for the response!
It's a Sagemcom SG4K10002816t, Unsure about the LED at the time of issues as I'd disabled it in the settings. I've just re-enabled it and there is a solid white LED on the now...
I've also updated my profile, thanks.
Skynet_TX
Message 8 of 9
Hi @Pajspaj,
What make of hub is it, the Sagemcom or the Huawei ?
If you have the Sagemcom then it is possible you are suffering from a known DNS issue that can affect a certain version of firmware on that router.
Does the LED remain solid white when you are having these issues.
