Difference between download speed and wi-fi speed.
Trenchn1
Message 16 of 16
I am getting good download speeds at my PC. Around 60mbps. My wi-fi speed though, with the latest Talk talk router is usually around 15mbps. Is this normal/reasonable or is it worth looking at a mesh system or something similar.
The 15mbps is with my device right next to the router, if I move further away, it drops to way below 10.
Any advice welcomed.
Cheers
Nick
15 REPLIES 15
Message 1 of 16
Hi Trenchn1
Would you like me to send a Huawei WIFI hub for testing to see how the connection compares?
Message 2 of 16
OK. So follow the instructions here.  And when you get to to the wireless settings for the 2.4GHz band change them so that the channel width is 20Mhz only. Then try channels 1, 6 and 11 respectively and see how you get on.
Trenchn1
Message 3 of 16
HG635 Super Router
Message 4 of 16
Which router do you have?
Trenchn1
Message 5 of 16
These are the instrutions from your link.
  1. Select Home Network from the menu bar at the top.   There is no home network or a menu bar at the top.
Message 6 of 16
When you select a wifi channel, you will usually have the option to select a channel between 1 - 13.
Generally 1, 6 or 11 are said to give the best performance, but that can also depend on the channels in use around you.  Try a channel number and test and see if there is any noticeable improvement in performance.
Message 7 of 16
2.4gig showing channel 10, 5.0gig showing channel 40
Trenchn1
Message 8 of 16
The article doesn't seem to relate. under channel it says automatic or some numbers, none of which are 1. 6 or 11
Trenchn1
Message 9 of 16
I have the latest talk talk router. What they call the Super router
Message 10 of 16
This Article will show you how to change the wifi channel based on the router model you have :
https://community.talktalk.co.uk/t5/Articles/Change-your-wireless-channel/ta-p/2204684
Message 11 of 16
Which router do you have?  Channels 1, 6 and 11 without bonding are generally best, but it is worth checking your local environment with a WiFi analyser if you can.
Trenchn1
Message 12 of 16
It's showing as using channel 10 but I don't know how to change it. All devices are pretty new.
Thank you
Message 13 of 16
Have you tried changing the wifi channel ?
Also, the device that is using wifi, is it a relatively newer device, so capable of higher speeds etc ?
You may find some useful pointers to help check the connection in our article :
https://community.talktalk.co.uk/t5/Articles/Boost-your-Wi-Fi-speed/ta-p/2205291
Trenchn1
Message 14 of 16
Yes, the PC is connected by ethernet, tha is getting around 60.
Chris-TalkTalk
Message 15 of 16
Hi Trenchn1,
Are you able to test on a device connected to your router by Ethernet cable so that we can see if it's just a wireless issue?
