Disable UPnP
OCE_Michelle
Hi Tom,
Could you run a wired ping and trace route and post the results into the thread so we can see how they compare?
Run a Ping or Traceroute
Lorik
Hi Keith,
Are you able to provide an estimated date for when the option to disable UPnP will be made available?
I find it baffling that TalkTalk would remove the option while knowing the security issues associated with UPnP. I also know for a fact that my old TalkTalk router (HG633) did have option.
Many thanks,
Lorik
Pricey1989
Hi Michelle
many chance you could disable my upnp please?
many thanks
OCE_Debbie
Hi Pricey1989
I'm sorry for the delay. Our Products Team have advised that we can't remove this.
Fifa King
Hi.....did you ever manage to get this sorted out? I have got the same problem but talk talk live chat don't even know what UPNP is!!!
Lorik
Hi Debbie,
In the following post (https://community.talktalk.co.uk/t5/Broadband/Switch-off-UPnP-on-Sagemcom-FAST-5364-router/td-p/2442...), the products team did indeed disable UPnP, can you please confirm the steps I need to follow in order to have the option disabled on my router.
Thanks,
Lorik
Parlez
After logging in to the router web interface, press F12 for a console and copy in the following before pressing enter to disable UPnP:
$.xmo.setValuesTree(false,"Device/UPnP/Device/Enable")
Or the following to re-enable UPnP:
$.xmo.setValuesTree(true,"Device/UPnP/Device/Enable")
