on 09-01-2022 04:25 PM
Can someone disable WIFI optimisation on my router?
The switching of channels is becoming more of an issue, I guess it is due to more devices in the near area. There is cleaner/empty channels (80mhz wide) high up in the 5ghz channels, but when set ATM the router moved back to a lower channel with other SSID on it.
Kenney
on 10-01-2022 07:30 AM
Hi Kenney
The WIFI optimisation has now been switched off. Please let us know how the connection compares.
on 09-01-2022 06:15 PM
Hi @kenney29,
Assuming you have the Sagemcom Wi-Fi Hub the staff should be able to do this for you when they return tomorrow.
