Disable portforwarding
shakir90
Message 2 of 2
I have a device which keeps getting ports assigned to it by UPNP which is affecting the device operation causing it to underperform. I have set my own port forwarding rule but its being overridden by the UPNP port number.
Since i cant disable UPNP or delete the port forwading rule by my self im hoping someone at talktalk can disable it on their end.
1 REPLY 1
Message 1 of 2
We are unable to disable this from here as we no longer have that access, but I can swap out the router for another model for you.
