Disabled Wifi
Aleksandrapj
Message 4 of 4
I just got my internet connected yesterday, everything was working completely fine until , Wifi network disappeared.
Router has got still white light everything looks fine but my devices cant even see a network. I have managed to connect my laptop through ethernet cable and this way - internet is working. I logged into my router and it says Wifi disabled - there is a an option to enable it  - when i press it nothings changing and wifi is still disabled. I have restarted my router to factory settings - that didn't help either. Looking at previous posts most likely I need router replacement? I have been on live chat but the person there didn't seem too helpful and didn't really took into consideration everything I said?
It is not really a great start to have it down on the second day of connection. Could anybody please advise me how to get this issue resolved quickly?
Thanks in advance!
3 REPLIES 3
Message 1 of 4
Hi Aleksandrapj
A replacement router is on the way.
Message 2 of 4
Just updated my profile, thank you! Hoping for TalkTalk staff to resolve it quickly 🙂
Skynet_TX
Message 3 of 4
Hi @Aleksandrapj,
If a factory reset (holding the reset switch in for over 10 seconds) has not got it working then the router probably has a fault. The staff here will be able to arrange a new router for you if they believe it is faulty.
