on 13-01-2022 11:11 AM
theres no option to disable UPNP in the Talk Talk router
TalkTalk Wi-Fi Hub
version SG4K10002816T
Could you direct me to enable any advanced settings that the option becomes visible
on 25-01-2022 09:59 PM
It will be closed because there is presumably no app to open that port in the device, or blocked by a firewall on the device if it has one. The fact that you can add the rule, means that UPnP is not disabled. I'll push this back to TalkTalk for you.
on 25-01-2022 06:04 PM
added bottom just now exactly as i added it in the app, however that port number remains closed when probed, so you maybe correct that it may be disabled..
on 25-01-2022 05:55 PM
Nope still active...
on 25-01-2022 02:53 PM
When I was testing V130, to prove that UPnP was disabled I used this tool in Windows "UPnP Wizard":-
http://upnp-wizard.findmysoft.com/
If it is enabled you can add a port forwarding rule in the router with it. If it is disabled you will see this when you try & run it:-
Have a go, at least it will prove if it is still enabled or not.
on 25-01-2022 01:57 PM
The Firewall is still showing entries in UPnP despite this being turned off and rebooted Router with the new changes
on 13-01-2022 12:16 PM
UPnP is now off in the router.
If you contact our business teams directly they can advise of packages and prices and discuss options with you.
https://www.talktalkbusiness.co.uk/contact-us/
on 13-01-2022 12:07 PM
This has now been updated, Thank You
one more question : Who do I contact in Talk Talk to change from a domestic customer to a Business one? the domestic package does not offer a static IP, Thanks
on 13-01-2022 12:02 PM
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
on 13-01-2022 11:41 AM
Hi Karl,
in response to the question there are entries in the UPnP that I have not set, I do not use this feature I prefer more control over the firewall than I currently have.
on 13-01-2022 11:35 AM
That is correct, but you can do it yourself from V130 firmware, but the rollout of this has been paused because of a problem that is currently under investigation.
on 13-01-2022 11:34 AM
In the current firmware there is no access to disable UPnP however this will be available in the future firnware.
Can I ask why you want to disable UPnP ?
