Disconnections
ShaneAFC
Message 18 of 18
Hello
I've had my TalkTalk Faster Fibre Broadband installed for 2 months and 95% of the time it's perfect, much better than what I'd been hearing about TalkTalk! The only issue I'm having is my internet connection being randomly disconnected. This can happen and then I'll go a week or 2 without it happening again or it could happen again 2 hours later.
The disconnection literally lasts for about 5 seconds so it's not the router restarting or anything, if it was it'd take a lot longer to come back on. It's just happened again tonight, I looked over the log and at the time of disconnect this is what it says.
26.11.2019 21:57:48	Info	SYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
26.11.2019 21:57:45	Info	IGMP
IGMP join received (239.192.0.0)
26.11.2019 21:57:44	Info	DHCPC
The WAN DHCP client IP address 92.23.XXX.XX
26.11.2019 21:57:42	Info	DHCPC
The WAN DHCP client process has successfully been launched on Vlan 36
26.11.2019 21:57:40	Info	XDSL
VDSL connectivity is up port 1
26.11.2019 21:57:37	Info	IGMP
26.11.2019 21:57:13	Info	XDSL
VDSL connectivity is down port 1
26.11.2019 21:57:13	Warning	DHCPC
The WAN DHCP client process has successfully been terminated on Vlan 36
I'm not sure if there's anything I can try my end, maybe this is normal for TalkTalk routers? It never happened with the Super Hub  (albeit that had its own issues!) when I was with Virgin Media. It's not a big problem as the internet comes back on pretty much instantly but if I could prevent it from happening altogether, that'd be nice! 😁
17 REPLIES 17
Message 1 of 18
Hi ShaneAFC
Message 2 of 18
Hello
The Openreach engineer has just left. A new line was installed. Hopefully that will stop my internet dropping out randomly.
I'll keep you updated if there are any issues.
Thank you for (hopefully!) resolving the problem.
Message 3 of 18
If you bump the thread on Friday, we can follow up with Openreach for you.
Message 4 of 18
Thanks for the update. I kept a log yesterday for the times (I noticed) it went down. 8 times in a 6 hour period!
18/02/2020 - 15:04
18/02/2020 - 15:14
18/02/2020 - 15:18
18/02/2020 - 15:23
18/02/2020 - 18:40
18/02/2020 - 18:42
18/02/2020 - 20:57
18/02/2020 - 21:00
Message 5 of 18
Hi Shane,
Ok thanks for confirming this. I've re-run the line test again and it has now detected a potential fault so I've passed this over to Openreach now for a line investigation to be completed and we should receive an update back within the next 48-72hrs.
Message 6 of 18
I was sent a new router when I first brought this issue up however that didn't change anything. I'm unsure if it was a different make or model but it looks the exact same as my original one.
Message 7 of 18
Hi ShaneAFC,
I'm really sorry to hear this and I'll take a look at this for you now. I've run a test on the line which hasn't detected a fault, however I can see some re-connections on the line. Could I just confirm, have you tested with a different make and model of router?
Message 8 of 18
I've tried living with this issue but 2 months later and it seems to be getting worse. I was fine with it happening randomly, once or twice a week but it's every single day now, multiple times.
Web pages will fail to load, I look over at the router and as usual it's flashing white, 10 seconds later and it's back on. Worse of all if I check the service center, it tells me my connection is fine. Is this TalkTalk's definition of 'fine'?
I'm starting to regret signing up now, especially being tied into an 18 month contract. Things started off so well but unfortunately, as I was warned, the service is just getting worse.
Message 9 of 18
Hi ShaneAFC
No problem 🙂
Message 10 of 18
Hello Debbie,
Update went through fine, thanks for that.
I'll be sure to come back if I continue having issues.
Thanks again to all.
Message 11 of 18
Hi ShaneAFC
Apologies for the delay.
I've updated your router firmware to the latest version. Please let us know how the connection compares following this.
Message 12 of 18
Hello!
I've swapped the routers around so hopefully no more disconnections. I did go insane for 10 minutes or so when trying to setup DHCP reservation for some of my devices on the new router. The setting isn't there! Turns out the router is on old firmware. Also explains why my configuration file from the old router wouldn't apply to my new router.
I did look around for the new firmware that adds DHCP reservation but all I could find was TalkTalk employees pushing the firmware to the router so I guess you'll have to do it for me when you can. Unless it updates itself during the night, of course. 😁
Thanks again!
Message 13 of 18
Hello Karl,
Thanks for doing that, hopefully it'll fix the issue!
Message 14 of 18
I've a feeling there could be an underlying line issue, but unable to see one from here.
I've a replacement Hub on the way so i can rule out a hardware issue, see if this also helps.
Message 15 of 18
Hello Michelle,
I've not noticed what the weather is like whenever I experience disconnections, could this be it? I'll have to wait for the next time it happens and see what the weather is like! As for the landline, we don't use it but, again, when I get disconnected I'll check the line and have a look.
Message 16 of 18
Hi Shane,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault, however I can see re-connections on the line. Does it appear to be weather related? Do you experience any issues with the voice service at the same time such as noise on the line or no dial tone?
Message 17 of 18
