on 30-03-2022 12:03 PM
We currently have a Fibre35 package, which in the small print suggests that the average download speed is 38 Mb/s.
When checking my online dashboard, the average speeds for the last 7 days is 27 Mb/s.
I understand that speeds will vary however, when checking the Openreach website for my address they suggest that we are capable of 'Superfast' speeds up to 80 Mb/s whereas the speeds we are receiving would suggest we are only receiving a 'Standard' broadband type.
Therefore I am wondering why I am receiving a less than average speed? Are we not receiving a FTTC connection?
Thanks,
Iain
on 31-03-2022 08:13 AM
Thanks for confirming. This should have a test socket in the lower half of the socket.
on 31-03-2022 08:10 AM
Hi Michelle
It looks the same as the NTE 5C MK 4 and has MK 4 written on it.
Thanks,
J.
on 31-03-2022 07:46 AM
Thanks for the update. The NTE5c main socket should have a test socket. Does it look like the below?
Your guide to main phone sockets - TalkTalk Help & Support
on 31-03-2022 07:41 AM
Thanks for the replies.
I have checked the socket which was recently replaced and I cannot see a test socket. It is a Master Socket 5c if that helps?
No worries I appreciate that it is al dependant on distance etc, there is a cabinet at the end of the street (100m away) and the exchange is located within the town - about 0.5 mile away.
I’m currently unable to get into MyAccount as the website doesn’t appear to be responding however, I think I am probably getting the minimum guaranteed speed.
I only really ask, as working from home and accessing the corporate network/ applications is some times slow and ICT support are blaming the connection speed which I find hard to believe! I am connecting to the corporate network using a Global Protect VPN.
J.
on 30-03-2022 01:22 PM
@Junkbot all FTTC services can provide up to 80 Mbps.
However, the speed YOU get at your home is dependant on the length of YOUR line to the fibre cabinet.
Some get the average, some more and some less, there is no ONE speed for FTTC.
Fibre 35 can actually provide 40/10 if you are close enough to the cabinet.
Your speed indicates you must be on a FTTC service as ADSL is not capable of 27 Mbps.
How does your speed compare to the minimum guaranteed speed seen in Service Centre.
on 30-03-2022 12:07 PM
I've run a test on the line now which is clear. Can I just confirm, were you previously receiving faster speeds? Does your main socket have a test socket please?
