Download speed issues
jamespinner
Message 12 of 12
I have been having some weird issues with my download speeds  and have ran out of ideas on what the problem could be.
For completeness i'm currently on the faster fibre plan (70mbps download and 20mbps upload)
I have been having some weird download speed issues where speedtests have been showing slow download speeds and downloading from the browser is really slow (see pictures below) and additionally i have been seeing alot of lagging while playing online games. However when i download a game through steam i get the full download speed and youtube also see a higher download speed.
I contacted talktalk through the live chat and was told that the connection to router was running at the advertised speed of 70mbps and it was a problem in my home and gave me the option of consulting my hardware manufactorer or paying £40 for an engineer to come out. As i was told the connection to the router was ok i decided to see if i could find the problem myself.
So far i have
- Replaced the ethernet cable, microfilter and adsl line with and without being connected to the test socket.
-reset the router, (live chat agent also reset the router to factory settings)
-updated then reinsatll the lan drivers
-Tried different ethernet ports on the router.
- tried a pcie network card and wifi card in my pc
- reset windows.
None of these have helped the issue, next i borrowed my friends ps4 and connected that to the ethernet (pics below)ps4 talktalk2.jpgps4 talktalk.jpgps4 speedtest2.jpgps4 speedtest.jpgps4 connection.jpg
As seen in the pictures the ps4 has low download speeds and fail at the upload test on the speedtests.
On looking online i find mention of router logs and upon looking at these i found instances of an ethernet port being connected and disconnected within a short space of time.
Ethernet port 1 at the time was my home pc.
Same occurs when ethernet in port 2
Image above shows ethernet disconnects for the home pc (ethernet port 1) and ps4 (ethernet port 4)
I really dont know what else i can do after this so any suggestions would be greatly appreciated before i have to pay £40 to get an engineer out.
Sorry for the massive post
11 REPLIES 11
Message 1 of 12
Hi jamespinner
That's great, thanks for letting us know 🙂
Message 2 of 12
HI,
Just an update, I have received the new hub today and the download speeds are so far back to the speeds i was expecting. Will update if anything changes.
Thanks for all your help
Message 3 of 12
No Problem 🙂
Message 4 of 12
Thanks,
I'll update here after i have tested with the new hub
Message 5 of 12
Hi James
i'll get a different model Hub to you and see if this is better.
Message 6 of 12
i included a pic as im not sure if it has a name only what i found on the router page.
i have tried 2 different ethernet cables connecting to both a desktop pc and a playstation 4 with the same results.
I dont have another hub to test with unfortunately.
Message 7 of 12
@jamespinnerso from the looks of that screen grab your Hub is getting 80Mbits down from the line which is good 👍
What's not so good is what's then coming out of the hub. What hub do you currently have?
Have you tried a different ethernet cable and/or device?
Steve -
Have you tried turning it off and on again!
Message 8 of 12
Please start your own thread,  @Tobywiltob.
You need to return to the message board and click on start a topic.
Also, you must complete your community forum profile details for TT staff to identify your account.
Please go via your avatar/name; settings; Profile Wizard.
Message 9 of 12
I am having the exact same issues at the moment and I've have tried everything and can't find a fix have youbhad any more luck?
Message 10 of 12
yes i am connected to ethernet when running the speed tests.
The service centre says everything is fine
Ste_Nix14
Message 11 of 12
Are you connected via ethernet when running these speed tests?
What speeds does Service centre report?
Steve -
