Download speed under max sync rate
edzusbalodis
Message 23 of 23
Download sync speed all the time running arround 20% under max rate. Why ?
22 REPLIES 22
Message 1 of 23
Do you have a printer that has an ink subscription, I think the monitoring app can cause this type of log entry
Message 2 of 23
No.
Nothing other than youtube in browser.
Doing lots of gaming here but there is no streaming services.
Message 3 of 23
They may have something to do with TV, the IP address appears to be a multicast address - are you using Netflix or another streaming service?
Message 4 of 23
Hey Chris.
Yes these logs keep poping with 5 second interval .
Date/Time Severity Module Message
03.09.2020 10:47:07InfoIGMP
IGMP group removed successfully (224.168.100.1)
IGMP leave received (224.168.100.1)
IGMP group added successfully (224.168.100.1)
IGMP group stream started (224.168.100.1)
IGMP join received (224.168.100.1)
03.09.2020 10:47:00InfoIGMP
IGMP join received (239.192.152.143)
03.09.2020 10:46:57InfoIGMP
03.09.2020 10:46:55InfoSYS
Modem login was successful
03.09.2020 10:46:47InfoIGMP
So i am not really sure why these keep going .
Cheers
Message 5 of 23
Hi edzusbalodis
Line test is passing, current sync speed is 65.9Mbps.
Have you continued to get the log entries?
Message 6 of 23
Hi there.
It might be more stable now but these keep appear. Currently have 1276 pages of log files.
02.09.2020 09:45:42WarningDHCPC
The WAN DHCP client process has successfully been terminated on Vlan 36
02.09.2020 13:47:10InfoIGMP
02.09.2020 13:47:02InfoIGMP
02.09.2020 13:47:00InfoIGMP
02.09.2020 13:46:50InfoIGMP
So i am not sure why it keeps happening .
Message 7 of 23
Hi edzusbalodis,
I'm sorry for the delay. How have you found the stability since this router has been connected?
Message 8 of 23
These are speed rates up to today.
Talk Talk siteTalk Talk siteSpeedtest.netSpeedtest.net
Message 9 of 23
Hi there.
Router is changed so if needed line can be tested again
Thank you once again.
Message 10 of 23
Hi edzusbalodis,
I'm sorry for the delay. I've re-run the line test which hasn't detected a fault and I can still see a few re-connections on the line. Do you have an alternative router that you can test with? If not then we can send a replacement router for testing purposes to rule this out.
Message 11 of 23
As we talked . I'll post results after 48hours test socket usage.
Results are interesting. Max rate decreased by 6Mbps and there is few more errors in downstream .
Message 12 of 23
Hi .
Thank you for the question it's been jumping like that since first time connected to talktalk network .
Message 13 of 23
Hi edzusbalodis,
Just to confirm, has the connection been unstable since the router has been connected to the test socket?
Message 14 of 23
UPDATE
Interesting ...
1392020-08-26 12:36:13DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1382020-08-26 12:36:12DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
1372020-08-26 12:28:42DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1362020-08-26 12:28:41DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
1352020-08-26 12:21:11DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1342020-08-26 12:21:10DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
1332020-08-26 12:13:40DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1322020-08-26 12:13:40DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
1312020-08-26 12:06:09DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1302020-08-26 12:06:08DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
1292020-08-26 11:58:38DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1282020-08-26 11:58:37DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
1272020-08-26 11:51:06DHCPCNoticeRecv ACK from server 92.14.80.1 with ip 92.14.94.34 lease time 900
1262020-08-26 11:51:06DHCPCNoticeSend REQUEST to server 92.14.80.1 with request ip 92.14.94.34
Message 15 of 23
Hi.
Sure I'll post results on Friday.
Message 16 of 23
Hi edzusbalodis,
Thank you. I've re-run the line test again now just to check if this is still clear, which it is. Would it be possible to post back here on Friday and we can re-check your connection stats again to see if DLM has made any changes to the sync speed?
Message 17 of 23
Hi .
It's done
Message 18 of 23
Hi edzusbalodis,
Thanks for confirming this. Would it be possible to connect the router at the test socket for at least 48hrs so we can see if DLM increases the sync speed?
Message 19 of 23
Thank you for the answer.
I can feel that speed is not there yet.
As for socket I have Master Socket 5C installed and unfortunately I dont have phone to test line noices .
Kind Regards
Message 20 of 23
Hi edzusbalodis,
I've run a test on the line which hasn't detected a fault, however I can see that the sync speed has dropped slightly. Does your master socket have a test socket? Is the voice service ok with no noise on the line?
