Drop Outs
templeside
Message 19 of 19
Two weeks ago I moved home and ever since have been having a nightmare with TalkTalk wifi dropping out and not connecting. Our phones struggle to connect just one room away (and it's not like we have super thick walls!) our ring doorbell is close and struggles, our Sky Q boxes are constantly struggling, both the mini boxes but also the main box which is two feet away from the router. I've tried everything. Resets, reposition, changing network addresses, changing the band, added powerline adapters and more but nothing is helping. It's at a stage where two weeks in its unusable.
Can anyone suggest anything else (other than pay for an expensive mesh network and hope that works) or am I just going to have to get it cancelled and move back to Sky who can then ensure all the sky boxes are working correctly.
18 REPLIES 18
Message 1 of 19
Hi templeside
How has the connection been with the new router connected?
Message 2 of 19
New router has arrived and is now installed.
Message 3 of 19
OK thanks (I've ordered it now so it should be with you within a couple of days)
Message 4 of 19
Thanks - I'll let you know when we have it
Message 5 of 19
OK I'll order you another router to test with, it should be with you within a couple of days
Message 6 of 19
Sadly not - just that one.
Message 7 of 19
Sorry, still can't communicate with your router, do you have another router you can test with? If not then we can send one
Message 8 of 19
OK I'll check it now and get back to you 🙂
Message 9 of 19
back online after 30 mins or so off - hopefully it'll work now for you.
Message 10 of 19
Message 11 of 19
Actually just realised we can do it now and tether off our phones... so it'll be back on in 30 mins
Message 12 of 19
OK thanks, it's fine to do it later and I'll pick it up again in the morning 🙂
Message 13 of 19
Yep. I can try it again but it won't be till later in the day as we need the wifi for work for the rest of the day.
Message 14 of 19
Hi templeside,
Thanks for that but still having problems communicating with your router, did you switch it off for at least 30 minutes?
Message 15 of 19
Thanks Chris - all rebooted
Message 16 of 19
OK thanks,
I can't communicate with your router at the moment so could you switch your router off and leave it off for 30 minutes then switch back on and let me know when you've done this
Message 17 of 19
Done!
Chris-TalkTalk
Message 18 of 19
Hi templeside,
I'm sorry to hear that you're experiencing problems with your service. Could you check the telephone number in your community profile and confirm that it's your current TalkTalk landline telephone number
