Drop in Broadband Speed
Jonsco79
Message 19 of 19
Hi all,
ive noticed a drop in my speed recently from a solid 33mb down to 26. Nothing’s changed my end and this is on a wired connection. Anyone got any clues as to why this may be?
thanks in advance.
18 REPLIES 18
Message 1 of 19
Hi Jonsco79
Thanks for the Private Message.
I have checked and the predicted speed range for your line is showing between 44 and 28.7mb, with a minimum guaranteed speed of 23.3mb.
Message 2 of 19
Hi Jonsco79
I can check the predicted range for your line. I'm just sending you a Private Message to confirm some details.
Message 3 of 19
Seems to be ok now, I take it this is the fastest my line can handle?
Message 4 of 19
Hi Jonsco79
Your line is showing in sync at 35mb.
Please can you power down the router for a full 30 minutes and then run another speed test?
Message 5 of 19
There are no issues with my modem and eero setup
Message 6 of 19
Hi Jonsco79
This is just to rule out any possible issues with the router.
Message 7 of 19
Hi Debbie,
Let me have a look here as I’m sure it’s just hidden! Can I not test with the modem and eero setup then? What exactly are we testing for?
Message 8 of 19
Hi Jonsco79
Would you like me to send you a replacement router for testing.
Message 9 of 19
No I’m using the eero mesh WiFi and didn’t keep the TalkTalk one sorry
Message 10 of 19
Before we arrange an engineer, do you have access to another router for testing ?
Message 11 of 19
Hi yep I tried that already this morning.
Message 12 of 19
Hi Jon,
Ok thank you for confirming. Could you try switching the router off for a full 30 minutes and then retest the speed again please as this will reset the current session and can often improve the throughput speed.
Message 13 of 19
Yep router is in the master socket and no other sockets in the property. We don’t use the landline and don’t even own a phone so I can’t check that one I’m afraid.
Message 14 of 19
Hi Jon,
Ok thanks for confirming. Is the router currently connected to the master socket at the moment and do you have any extension sockets? Is the voice service ok with no noise on the line?
Message 15 of 19
Hi Michelle,
No it doesn’t it’s a very old socket.
Message 16 of 19
Hi Jonsco79,
I've run a test on the line which has detected a possible issue towards the property. Does your master socket have a test socket?
Message 17 of 19
Cheers done now
Gliwmaeden2
Message 18 of 19
For staff to address your particular situation,  please complete your community forum profile details, @Jonsco79.
Go via your avatar/name; settings; launch profile wizard; make sure you put in your landline phone number and a fallback mobile phone number; click finish to save.
Staff reply during business hours Monday-Friday.
