Dropped Broadband fibre speed
millet2010
Message 7 of 7
Help!
My TT Fibre has always got approx 65 down and 14 up but we had a powercut in the village two weeks ago and after power was restored I was getting 80 down and 20 up. This lasted until yesterday when I restarted the hub and my speed down (at the router) had dropped back to 65 down and 14 up?
I called TT this am which was pointless apart from having my router remotely reset and restored to defaults to which I have now had to spend 20 minutes fixing!
Any ideas on how to get my 80/20 back? It's clearly possible when I've had this for the last two weeks?
Thanks, Tony.
6 REPLIES 6
Message 1 of 7
I've run a full service test on your line to verify settings.
Your line profile is currently set at 80/20.
The Router is in sync at 61mb.
The estimated range for your line is 51 - 73mb.
So the service test is reporting that your line is performing as it should.
Message 2 of 7
I don't think the speed was altered by DLM as it was 80/20 for 2 weeks and only reverted when my router was (mistakenly) unplugged yesterday and then went back to 64/14 😞
It's a shame TT cannot request this as it can be done remotely and not even need an OE engineer to visit the cabinet 😞
Message 3 of 7
This is not something we have been able to reset and if the speed of your line remains within the predicted rate as issued by Openreach our network teams would not request this.  Also, if your line were reset and DLM has previously lowered, it would lower the profile again.
Message 4 of 7
H Karl, apparently ISPs can "request a caution counter reset on a number of their lines each day" from Openreach? Article https://www.ispreview.co.uk/index.php/2018/02/ability-reset-openreach-fttc-broadband-dlm-profiles-ar...
How do I request this from TT without a world of hurt calling again 😮
millet2010
Message 5 of 7
Thank you Karl 🙂 Just need to have a powercut more often and after restoration not ever restart the Hub as 80/20 was amazing for 2 weeks 😄
Message 6 of 7
The speed of your line is controlled by DLM (Dynamic Line Management) on the Openreach side.  If the line was fully reset after an issue, DLM will start at the maximum and if any issues or errors are detected then DLM will change the line profile and balance speed with stability to ensure a more robust connection.  We have no control over DLM and this is fully automated.
