Dual band?
Georgeivs
Message 10 of 10
Hi, I need to know if my router is dual band as I need need it to connect to the 2.4GHz band rather than 5GHz.
George
9 REPLIES 9
Message 1 of 10
Message 2 of 10
I got everything sorted out at the weekend and your information was very helpful.
Thanks again,
George
Message 3 of 10
Thanks Martin, I'll let you know how I get on
George
Message 4 of 10
The router will transmit both bands at the same time, so giving them different names will make it easy for you to see which provides the best signal in each area of your home.
The 2.4 Ghz band is better at penetrating walls than the 5 Ghz.
With modern devices both bands can provide speeds to devices in excess of the incoming broadband speed although the 5 Ghz band can connect at faster speeds.
If you have close neighbours then WiFi interference can be a problem and the Sagemcom has a feature that supposedly connects to the best channel in your area but that itself has been known to be unreliable.
Message 5 of 10
By default the bands are named the same so devices that support either bands can connect to the most appropriate fpr distance and speed etc.
Steve -
Have you tried turning it off and on again!
Message 6 of 10
Thanks again Martin,
I'll try working it out, but I'm no IT expert.
It is a Sagemcom, so being dual band, I suppose you can switch from one to the other? But is one better than the other between 5 and 2.4? Obviously, if a product does not work with 5 GHz 2.4 is better! Shame they don't make everything universal for the benefit of people like me (easily confused by IT)
George
Message 7 of 10
You have the Sagemcom HUB, so it's dual band.
You can give each WiFi band different names if you wish.
https://community.talktalk.co.uk/t5/Articles/Split-your-router-s-SSID-wireless-network-name/ta-p/230...
Message 8 of 10
Thanks Martin,
I'll try that. The router is Product Version: Fast 5364-3 TB/AV3.C1, but if they are all 2.4 there must be some other problem stopping me linking a remote plug.
George
martswain
Message 9 of 10
@Georgeivs  what model router do you have ?
Log in to the interface at 192.168.1.1 using the details on the back.
They are different to the WiFi details and may be behind the pull out card.
Then go to the Wireless Setting and see if there are details for both bands.
All TT routers and HUBS have the 2.4 Ghz band as standard.
