EchoLife DG8041W dropping Ethernet Connections
Stratosphere
Message 11 of 11
EchoLife DG8041W, firmware 1.06t, Ethernet connections are dropping out, sometimes unplugging and plugging back in works, not always.
Currently have Humax TV box, Playstation 5 (Won't connect via Ethernet at the moment) and a powerline adapter plugged into Ethernet. Had problems with the Humax a couple of weeks ago, swapping the cable to a different port on the router fixed it temporarily, now working OK.
Now the PS5 won't connect, swapping ports doesn't seem to fix it, very odd, any ideas welcome!!
10 REPLIES 10
Message 1 of 11
Hi Edward
That's great, thanks for letting us know.
Message 2 of 11
All working thank you, old router is in the post coming back to you. Thank you once again.
Message 3 of 11
Hi Edward
Message 4 of 11
New router arrived, seems we're back on a Sagemcom FAST5364 3.00 - version SG4K10001400t (I think that's what we had previously to the EchoLife DG8041W but I'm not entirely sure now).
The important bit is that we're all back up and working on Ethernet (and WiFi) now so thank you so much for the outstanding support!
I'll monitor for a few days before sending the DG8041W back if that's OK, then mark the issue resolved of course.
Once again, thank you for the outstanding support!
Edward Cunliffe
Message 5 of 11
Hi Edward
Message 6 of 11
Yes please Debbie, that would be great thank you!
Edward Cunliffe
Message 7 of 11
Hi Stratosphere
Sorry for the delay.
Would you like me to send a replacement router for testing?
Message 8 of 11
My thoughts too Keith, thank you for the input.
Message 9 of 11
It could be a faulty router, I'll ask TalkTalk to investigate, but it won't be until Monday now.
Stratosphere
Message 10 of 11
P.S. Have tried hard reset of router, problem persists.
