Eero 6 and google home hub
Vickyfluff
Message 22 of 22
Hi, I have eero 6, since getting it my Google home hub mini and Google nest do not work properly, they are connected on the 2.4ghz band but when I ask something it doesn't work, they worked fine on the old router? Help please!
21 REPLIES 21
Message 1 of 22
OK thanks. If all else fails your the wifi hub should work fine with your current service but could you try speaking to eero support via your eero app, hopefully they'll be able to help with this issue
Vickyfluff
Message 2 of 22
Talk talk hub
Message 3 of 22
Could I just ask which router you previously had, prior to getting the eero?
Vickyfluff
Message 4 of 22
Yes, I have even tried removing it and then adding it again.
Message 5 of 22
OK thanks, Have you tried rebooting the home hub?
Vickyfluff
Message 6 of 22
Yes, works via the app always, just voice commands, it lights up when I say hey Google, then will only sometimes respond!
Message 7 of 22
Does it always work via the app? Is it just the voice commands that don't work?
Vickyfluff
Message 8 of 22
Yes, last night it worked to turn lights on but not off, had to use the app, then today they wouldn't turn on unless I used the app!
Message 9 of 22
Hi VIckyfluff,
Is the home hub mini in exactly the same place as it was before you installed the eero?
Vickyfluff
Message 10 of 22
Yes, and the same for the bulbs
Message 11 of 22
Thanks for confirming. Have you tried assigning the google home mini a static IP?
Vickyfluff
Message 12 of 22
hi Michelle, yes have tried all of that, the connectivity isn't an issue as it is connected to the WiFi, I can broadcast to it, just it won't answer any questions or do anything, it will tell me the time. When it's not connected it would say not connected to the Internet!,
Message 13 of 22
Vickyfluff
Message 14 of 22
Still only works intermittently!
Message 15 of 22
How are you getting on?
Message 16 of 22
Ah, I guess your linked account is not an Amazon account.  To activate the Smart Home Hub you need to link an Amazon account to the eero app.
OK, let's just for the moment work on the basis that the Google devices are connected to the eero but aren't seeing the Internet.
What I would try is switching off IPv6 in the eero app just in case the devices are trying to connect with IPv6 protocol.
  • Settings tab
  • Network Settings
  • IPv6 Off
The TalkTalk network doesn't yet support IPv6.
There's also the possibility that the Google devices expect to use the Google DNS.  The eero as supplied by TalkTalk has an eero Secure subscription that requires the eero to be locked to the TalkTalk DNS.  You can select the Google DNS but this means disabling all eero Secure protection features.
GondolaVolunteer 2017-2022
  Like below to appreciate my help . . . Mark as solved  Accept as Solution
Vickyfluff
Message 17 of 22
 I dont have that option?
Message 18 of 22
Zigbee Smart Home Hub
  • Select the Discover tab on the eero app
  • Select Amazon Connected Home
  • Select Smart Home Hub
  • Select the i icon at the top to the right of Smart Home Hub
  • Then select the blue panel 'Discover Zigbee devices'
Vickyfluff
Message 19 of 22
Vickyfluff
Message 20 of 22
Can't see anything about Zigbee in the app? Whats odd is they are both connected, will the reset fix it? I have powered them off and also reset the eero.
