on 27-05-2022 03:44 PM
Hi. I've got the standard Fibre 65 (not Future Fibre). Our old TalkTalk router wasn't covering the whole house so I've set up an eero pro 6 mesh network with the router in bridge (WiFi disabled) to work as the modem.
Everything is working great but I was wondering if it's possible to connect the eero pro 6 directly to the line coming in and do away with the old TalkTalk router?
I originally thought that now eero pro 6 is PPPoE capable that it would work, but from some of the posts I've read on this forum, TalkTalk doesn't use PPPoE.
I've been trying to find instructions or a post on here but I can't seem to find anything.
Thanks in advance.
on 28-05-2022 09:01 AM
Thanks for the info. Much appreciated.
on 27-05-2022 05:01 PM
You need a VDSL modem as the first device on the line.
The eero is just a router, so you cannot use it on its own.
