on 18-11-2021 08:43 AM
My iPad mini on iOS 9.3.5 will not connect to the internet. Is it because it is old, out of date?
I have rebooted both the iPad and my eero which made no difference.
#eero
Please keep posting your trial feedback here or report any personal non-trial specific issues via email to talktalktrials@talktalkplc.com
on 18-11-2021 11:04 AM
This is usually under WiFi settings. IPV6 can be left turned off and will not affect the connection.
on 18-11-2021 10:30 AM
Where should I look for that setting? - On eero App, I looked in Network Settings but cannot see it mentioned.
I did notice that IPv6 is turned off... is this related and should it be turned on?
on 18-11-2021 10:26 AM
OK thanks. Do you know if WPA3 is enabled in the eero settings?
18-11-2021 10:16 AM - edited 18-11-2021 10:17 AM
Hi Chris, yep, I see this error message:
PS Apologies for comedic, grandiose network name!
on 18-11-2021 10:09 AM
Hi Lynnes,
What actually happens when you try to connect your iPad mini, do you get an error message?
18-11-2021 09:26 AM - edited 18-11-2021 09:26 AM
Yep, mine does still connect to other broadband networks.
18-11-2021 09:24 AM - edited 18-11-2021 09:25 AM
Sorry, I did not spot it in those first paragraphs, thanks... couldn't see the wood for the trees! That explains it; sadly, I knew it would become outdated sooner rather than later.
18-11-2021 09:08 AM - edited 18-11-2021 09:12 AM
My iPad Mini, iOS v9.3.5, connects just fine @Lynnes, and I have just downloaded 6 application updates, so your problem may well be down to the eero!
~R.
on 18-11-2021 09:07 AM
No problem 🙂 This is also included in the Help Guide in my last post too.
Thanks 🙂
on 18-11-2021 09:04 AM
Thanks, Michelle, I suspected as much.
Just wondering if it would make sense to have this detail 'eero currently supports devices running Android 7.0 or later and iOS 12 or later (tablets included).' available on the help page then customers may not need to raise a case?
Or is it already noted somewhere and I didn't find it?
on 18-11-2021 08:48 AM
I've included a Help Guide below,
