Error message when assigning port 80 "The configured port conflicts with the internal service port."
Ellie369
Message 9 of 9
I have been unable to find any suitable work around for this known issue within the Huawei DG8041W router (see link below). Even attempting to use acme.sh (https://jmorahan.net/articles/lets-encrypt-without-port-80/) for development testing is hit and miss.
If a router exchange is the only fix for this issue, can you tell me what the expected down time for the MAC address to update would be ?
https://community.talktalk.co.uk/t5/Fibre/The-configured-port-conflicts-with-the-internal-service-po...
8 REPLIES 8
Message 1 of 9
Message 2 of 9
Hi @Debbie-TalkTalk
All is well, my only real nitpick is the no NAT loopback, but in reality, for the most part, I'm going to dev test through Cloudflare's proxy, which bypasses the task of setting up my local hosts file to point at the LAN IP. Failing that, as long as Let's Encrypt has access to port 80 then that's the main thing.
I've bagged/labelled the Huawei router and will send it back tomorrow (Monday).
Thanks again @Debbie-TalkTalk and @KeithFrench
Message 3 of 9
Hi Ellie369
How are you getting on, have you received the replacement router?
Message 4 of 9
Hi Ellie369
The router is on its way. Please can you connect the new router and use the new wireless password on the back of the router.
You should receive this within the next 24-48hrs. Please let us know how you get on.
Message 5 of 9
Whichever router you get will be plug N play, but you must allow at least 30 minutes with both routers turned off. Then you may want to tweak some settings in the router to meet your requirements.
Message 6 of 9
Hi @Debbie-TalkTalk
I would like that, but I'm guessing it is not a simple case of plug & play. Can you give me a rough estimate regarding expected down-time please ?
Message 7 of 9
Hi Ellie369
Would you like me to send you a different make and model of router for testing?
Message 8 of 9
I have asked one of TalkTalk's OCEs to pick your thread up and consider a different router for you.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
