Ethernet Ports suddenly stopped working
Emjayar
Message 6 of 6
Have been using ethernet connection on my Sagemcom TalkTalk FAST 5364-3.T8 since installation back in August last year without any issues at all, but since today I have no connectivity with ethernet, WiFi is working perfectly fine on both 2.4ghz and 5ghz.
I do use a pair of powerline adapters and at first I thought they were the issue as they have a tendancy to drop out every now again, however after cycling their power I still do not have any ethernet connectivity.
Steps taken so far;
1. Taken powerline adapters out of the loop and connected directly to router each ethernet ports 1 through 4
2. Cycled router power many times.
3. Performed factory reset on router
Still no ethernet connectivity.  Is this a common fault?  Could you please advise next steps,  I have updated my profile with relevant account/contact details
Router version SG4K10002816t
5 REPLIES 5
Message 1 of 6
Hi Emjayar,
Thanks for the update 🙂
Message 2 of 6
@Karl-TalkTalk  The replacement router arrived and the problem is now resolved.  Thanks for your help, appreciate it.
Message 3 of 6
A replacement router is on the way to see if this helps.
Message 4 of 6
Ok, thank you.
Skynet_TX
Message 5 of 6
Hi @Emjayar,
If a factory reset hasn't fixed it then it is likely to be a fault with the router. The staff here will hopefully be able to respond tomorrow to help.
