Ethernet cable
Alsbells28
Message 3 of 3
Can i use the ethernet cable as my broadband cable didnt fit but ethernet cable did?? Sorry not good with this stuff
Message 1 of 3
Hi Alsbells28
Just to confirm, what issues are you experiencing? Are you wanting to connect a device wired to the router?
Message 2 of 3
That is impossible to answer without know what you are trying to connect with each cable type. These are totally different cables & are not interchangeable at all.
