Ethernet doesn't work on new WiFi router
matt617
Message 22 of 22
I have a router (SAGECOMFAST 5364-3.T8)  which will not allow devices to connect to the internet (or even each other) through wired connections. WiFi works fine.
I have a Synology NAS, Tado, EE signal booster and Macbook, none of which can get internet access when plugged directly into the router.
The router thinks the devices are connected, and other devices can use wifi with no problems.
I've tried resetting, configuring static DNS, nothing works - i.e.
If anyone from technical support can offer some alternative steps to try then please let me know.
21 REPLIES 21
Message 1 of 22
Hi matt617,
I'm sorry for the delay. Did you receive a router returns bag?
Message 2 of 22
Yikes, I'm really not doing well looking into this.
Current situation is the NAS drive and Tado both work when wired into the router but my laptop does not.
For now I'm just using wireless and that'll do.
Do you want me to send back the router?
Message 3 of 22
Hi matt617
Just to confirm, is this only affecting one device or are you unable to connect wired to any device?
matt617
Message 4 of 22
Thanks, for the advice / suggestions. Sorry it's taken me so long to reply, I do appreciate the help.
Static DNS was already enabled - I think I might have tried it after reading a similar post.
When I try to connect to the internet via the wired connection I can ping the router but the error message in the browser is just the standard one you see if you have no internet connection.
Message 5 of 22
Try this.
The only way I can get my Windows 7 pc to connect to internet by ethernet cable with the Wi-Fi Hub is to do the following:
Log in to WI-FI HUB > See internet settings > Manage advanced settings > Talktalk Wi-Fi Hub > DNS > Turn on Static DNS Server Configuration.
In the Primary DNS Server box type 192.168.1.1 and reboot the computer.
How come this works for me? Don't ask.
It might be worth a try for you. Only takes minutes.
Message 6 of 22
Hi matt617,
Thanks for the update. What happens when you try to connect wired? Do you receive any error messages?
Message 7 of 22
I tried to reply to this a few days ago but I guess I didn't click "post" because I can't see it.
Update is - I fixed the issue with the NAS, which was resolved by resetting the network settings of the NAS, so seemingly no problem with the router.
I still can't access the internet via the cable though. Do you have any more suggestions of things I can try please?
Message 8 of 22
Hi matt617,
Ok thanks for confirming this. I've updated the firmware now to the latest version. Could you retest and let us know if their is any improvement please?
Message 9 of 22
The router connected is the replacement you sent - seems to be the same as previous: SAGECOM FAST 5364-3.T8.
Message 10 of 22
Hi matt617,
Is this a different make and model to the original router? Which router is connected at the moment? (make and model)
Message 11 of 22
Hi Debbie
I'm sorry I haven't replied for a while. This new router seems to connect to one of my laptops but I still can't access the NAS drive.
What's the next step? I assume I'll have to send back one of these routers.
Matt
Message 12 of 22
Hi matt617
Debbie 🙂
Message 13 of 22
Yes that's fine, thank you! (=
Message 14 of 22
Hi matt617
I will send the router to the address linked to the telephone number in your Community Profile, will this be ok?
Message 15 of 22
Yes please. Can I presume you have the address on the account based on my profile information?
Message 16 of 22
Hi matt617
I can send a replacement router for testing, would you like me to arrange this?
Message 17 of 22
Yes, tried just with a different one - the cable supplied with the router.
Message 18 of 22
Hi matt617
Have you tested with a different Ethernet cable?
Message 19 of 22
Hi Matt, yes I read that the first time, but as the guy in the earlier thread found it worked for him.
Your post has been flagged for assistance and you should hear during tomorrow.
Please check your community profile and add your landline phone number it is used to identify your account. Please don't post personal details here.
Good luck with a resolve.
Message 20 of 22
Thanks for your suggestion, yes I have reset the router.
