Extender not compatible with Hub
Kirsten2
Message 14 of 14
I am really hoping someone can help me out here.  We used to have normal fibre broadband using a very old Huawei router.  We have always used a netgear ex7000 and enjoyed good strong wifi to the end of the garden.  Since 'upgrading' to the fibre 150, the extender no longer holds a connection and now has stopped connecting completely - it is showing as having a full signal, but the internet is not working - no pages will load.  We can't go back onto the old router as the master socket has been changed and it only works with the new hub.  So frustrating as this hub is meant to be better but we have had nothing but trouble with it!  Does anyone know if a new extender will fix the issue and if so any recommendations for something that is compatible with the hub?
13 REPLIES 13
Message 1 of 14
I get this error?
It looks like the webpage atXXXXXXXXXXXXXXXXXXXXXX might be having issues or it may have moved permanently to a new web address.
Message 2 of 14
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
Message 3 of 14
Thank you Karl
Ironically the connection has been more stable recently with the extender, but still not as good as it was on the old router.
Keith - any suggestions you may have would be much appreciated!
Message 4 of 14
Hi Kirsten2
optimisation is now off for you.
Message 5 of 14
Hi @Kirsten2
As @martswain has said, the OCEs can definitely do this for you. It would not surprise me, although this is just a guess, that the OCEs have access to more remote access configuration than the call centre staff.
Message 6 of 14
@Kirsten2  as per post #6 from @Debbie-TalkTalk , she or another OCE will be able to complete your request once they are back from their Easter break.
Message 7 of 14
So after 2 hours on the phone Talktalk are more saying they can't disable optimisation?
Message 8 of 14
I've completed my profile with the information. Talktalk please disable wifi optimisation as previously requested. Thanks
Message 9 of 14
Hi Kirsten2
Please can you add your name and TalkTalk landline number to your Community Profile.
I can then switch off the WIFI optimisation.
Message 10 of 14
Thank you Keith, that would be great.
Talktalk, can you please disable Wifi Optimisation?
Message 11 of 14
Yes you are correct about Powerline technology & separate electrical ring circuits.
The problem is probably caused by WiFi interference degrading the signal between the Sagemcom & the Asus. Any changes in other peoples routers in your immediate vicinity can introduce such interference that wasn't there the previous day/week or month etc.
However, before looking into this, you will need to ask TalkTalk to disable their remote diagnostic utility called "WiFi Optimisation", otherwise, it can overwrite any changes that I might suggest to do with its WiFi configuration. To get it disabled, all you have to do is to reply to this post, requesting that they disable it for you.
Once it has been done, I can help you with the interference issues, if you want me to.
Message 12 of 14
Thanks for your reply - yes it is definitely a hub.  When we upgraded and engineer came out and changed the master socket, installed an openreach modem and connected a talktalk hub.  It is a Sagecom 5364.
My issue is that the Netgear EX7000 has worked perfectly well with the previous router for about 5 years, it just does not seem to be compatible with the hub.  The wifi in the house is fine, and the extender used to mean that we could work in the home office in the garden no problem before we upgraded.  Yes, it is connected to the hub via wifi, but why would it deteriorate with supposedly a superior product compared to the previous 5 year old Huawei router?
It is not possible for a powerline to be used as the office is not on the same circuit as the house.
I really am at a loss as to why it has stopped working.
Message 13 of 14
This is a very complex issue that is impossible to answer with any degree of accuracy currently. Please can I have a few more details so as I can try to help you?
You say that you have a hub, are you sure that you do not mean a dedicated modem, as I doubt that any hub is compatible with Fibre 150 without a separate modem. However, if you do have a hub as well, what make/model is it.
I have had a quick look on the Netgear site & from what I can see, the ex700 connects back to the hub, via the hub's WiFi, is that correct? because if it does then this could be the problem. The product description says that it is a range extender, which is not really the same as a WiFi extender and yet it also calls itself a mesh network, which I would have thought that it would connect back the hub, or directly to the fibre modem via an Ethernet connection?
Talking generically & if my assumptions above are correct, this ex7000 will broadcast the regenerated WiFi signal out in all directions, including back towards the hub. If the hub & Netgear use the same WiFi channels, then the Netgear could cancel out the signal from the router, thus disconnecting the Netgear completely from the router & the internet. A true WiFi Extender does not have this problem, as it connects back to the hub, via powerline technology over your mains wiring.
Do you have a big property, i.e. will a Wi-Fi extender suffice or mesh be more suited to your requirements?
