Fast Fibre filter master socket?
3 REPLIES 3
danie1
Have put an order in for fast fibre.
My current openreach master socket is split across the faceplate so the phone goes in and the broadband goes in.
Will fast fibre work optimally with this or will I need to request openreach to install a new faceplate/master socket that works with best with fibre?
Please advise?
OCE_Chris
Hi danie1,
If the socket has a dedicated phone and dedicated broadband socket it should work fine with fibre
CHris
danie1
Hi thanks Chris,
It's this faceplate
https://www.run-it-direct.co.uk/adsl-vdsl-faceplates/btvdslfaceplate/
It looks like it supports speeds of vdsl.
Hopefully this should produce optimal speeds.
OCE_Chris
Yep that should work fine with fibre 🙂
