Fast fibre is intermittent and slow - how do i report it?
jelgood
Message 6 of 6
Hi, I've had a fast fibre for a while but recently it's been very up and down.  Often very slow - less than 2mb/sec, or it drops out completely for a few minutes.  I've tried calling and online support (although can never get onto the chat feature) but the machines keep telling me everything is ok.  I've tried everything and suspect i need a new router - how to i actually speak to someone to get this resolved?
5 REPLIES 5
Message 1 of 6
Message 2 of 6
Many thanks.  I'll let you know as soon as I've tested it out 🙂
Message 3 of 6
Hi jelgood
I've completed a line test which hasn't detected any faults so I have ordered a replacement router for testing.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
Message 4 of 6
Thanks, I've updated my profile.  I think the tests have been run already through the online help but didn't find any issues.  I also went through the set up info again.  A reboot helps, but only for a short time then the speed dips again.  Hopefully this can get sorted soon as it's making working from home impossible. Thanks
Skynet_TX
Message 5 of 6
Hi @jelgood ,
The staff here will be able to help, they can run some tests, and if they do believe the fault is with the router they would be able to arrange a replacement.
