Faster Fibre - Download 1.8Mbps / Upload 1.4Mbps - TalkTalk for real?
kaspac
Message 30 of 30
Online community is the last resort. Since 20/07/2019 my service has dropped radiclously. Basically if I wouldn't have unlimited mobile data I would not have access to web since this time - I'm working from home during the evening so it's even more frustrating. I have contacted TalkTalk support 4 times already and the only thing was done I went through the tests wasting approx 5-6 hours of my life without getting issue sorted. Today besides the fact attitude of the consultant was unacceptable  almost 2 hours chat and test ended with conclusion everything is okay and I can only complain. Is this for real guys? I have TalkTalk over 3 years and I resigned from other supplier due to the poor customer service, not due to the poor speed.
Just to clarify what was done so far:
  • 3 online test have been run by Tech Support
  • 3 times router restart - 30 minutes
  • Connection tested on 2 iPhones, MacBook, Android phone, AppleTV (Streaming) and finally wired using Dell laptop with Windows 10.
  • Master socket unscrewed and connection tested through the test socket - same speed on the test socket
  • There are no signs of any damage cable coming to the property form the cabinet. Also there is no sign of cabe damage inside the property
  • There were no modifications done to the equipment
  • There were no new devices added to the home network
  • There was a repair case opened on 22/07/2019 which has been closed since there are no issues(!) with my internet connection  (REP-5862393)
  • At the end I have received "Supermail from TalkTalk"  which doesn't bring anything new to what I have done so far.
Please see the test run just before posting the message:
Can someone suggest any other solution apart from changing the provider regardless of the potential cancelation fee?
Many thanks,
Kat
29 REPLIES 29
Message 21 of 30
I’ve tried one more time with wired connection - same results. I have connected previous router and both connections, wireless and wired gave speeds between 1.5Mbps to 1.8 Mbps. Any ideas?
Message 22 of 30
I have old Huawei HG633. Don’t remember if everything was okay with it or not since I got it replaced with newer version. Should I try to connect it?
Message 23 of 30
Message 24 of 30
Hi @Michelle-TalkTalk
I’ve done this yesterday evening by pressing and holding reset button for 30 seconds. Did not help. Tested speeds were between 1-2 Mbps.
Thanks,
Kat
Message 25 of 30
Hi Kat,
Have you tried factory resetting the router and then retesting this again?
Message 26 of 30
I’m bit confused since I can’t find options mentioned by you on my router page.
 When I go to the WI-FI setting I got this screen which allows me to disable one of the bends or WI-FI connection. I have switched off 2.4 Ghz band and there was no speed improvement. Pages were loading very slow. I also tried to connection witch 5 Ghz band switched off and I have had same results:
When I go to Internet settings I get below screen:
From where I can access more advanced settings of the bands:
Also I have had call from Talk Talk running one more time their tests. I was told that this is caused by number of devices connected to the network 🙂 even thought there was no single issue since I got TalkTalk service. All setting have been “restarted” and I’m waiting for the follow up phone call on Tuesday 🙂
I will try one more time with wired connection tomorrow evening but last time I have checked it resets were exactly the same. Is there any chance router can be faulty?
Many thanks,
Kat
Message 27 of 30
Your router is getting a download speed of 69M, I would suspect that your problem is WiFi interference.
The HG633 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. This is available on the HG633 (V2.00), to enable it, first set both SSIDs to the exact same name. Then go to:-
Home Network > Wireless Settings > Enable Wireless Network Frequency Bands
Then put a tick against Enable Band steering.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Windows 10 1903 intermittent WiFi issues
With the May 2019 feature update to Windows 10, some older computers may experience loss of Wi-Fi connectivity due to an outdated Qualcomm driver. Please see this from Microsoft:-
https://docs.microsoft.com/en-gb/windows/release-information/status-windows-10-1903#445msgdesc
Message 28 of 30
I use wireless connection only (there is philips hue hub connected via cable to the router). i just tested wired connection to see if there is any difference between but the speed test gave me exactly same results. Until Saturday speed was oscillating around 60mbps.
Pasting data from the router:
xDSl
 StatusConnection TimeLink StatusStandardLine EncodingLink Encapsulation
Line 1
UP
01h52m17s
UP
VDSL2 (G_993_2_ANNEX_ B)
DMT
ATM (G_992_3_ANNEX_ K_ATM)
Line 1
DownstreamUpstream
6699719000
6914819000
6.908.00
16.900.00
13.007.10
thanks,
Message 29 of 30
Speed tests only give the whole picture, they do not help in locating the fault.
How do you connect wireless, wired, or a mixture? If a mixture is a wired connection better than wireless?
It is important to see what your line is actually capable of and what your current download speed is.
To help diagnose this issue, please can you log on to your router, by opening a web browser (e.g. Internet Explorer, Mozilla Firefox & Google Chrome etc) and then enter this address in the address bar:-
http://192.168.1.1
enter the credentials:-
username: admin
password: admin        (unless you have set your own password).
If you use the HG633 & DSL-3782 or the TalkTalk Wi-Fi hub, they have their own unique password, which can be found at the top of the label on the rear of the router. It is the one labelled "router" or "admin" password, not the wireless one.
Then go to your ADSL or DSL summary page & paste the stats in this thread.
On the HG633 this is at:-
Maintain > System Information & expand Broadband Information
On the DSL-3782 go to the home page & copy the stats from the DSL & IPv4 pages.
If you have the new TalkTalk Wi-Fi hub this can be seen via:-
Dashboard > See internet settings > Manage Advanced settings > TalkTalk Wi-Fi Hub
Click on the General tab then scroll down to the page to the xDSL section & copy & paste them into your reply.
