Faster Fibre Speed dropping over time
berryr99
Message 12 of 12
My Faster Fibre speed has dropped from 32.1 Mbps down and 9.2 Mbps up, in November 2018 to 2.5 Mbps down and .8 Mbps up today. It has been stuck on 2.5 for the last week and I was seeing 27.9 and 7.8 until 3rd December - the next day it was 4.4 and 5.5. The minimum guaranted is 39 Mbps.
The Hub is always on and connected to the Master socket. The landline is working fine.
I have tried the 30 min powerdown and also a router swap to an HG 633 but no improvement seen.
Received the attached email from TalkTalk on 12th December ( which I responded to) but nothing has changed.
Just wanting a bit of help with this.
Robert
11 REPLIES 11
Message 1 of 12
Hi Robert,
That's great news, thanks for the update
Message 2 of 12
Hi Michelle
I re-set the router yesterday and I'm seeing 24.1 down and 8.6 up.
Its been very stable and the speed meets my needs
Don't propose to re-post unless there are further problems and thanks for your help
Robert
Message 3 of 12
Message 4 of 12
Thanks Michelle
I'll do the router reset later today and report back
Robert
Message 5 of 12
Hi Robert,
Thanks for the update. I've re-run the line test which is now clear and the sync speed also look ok. Could you try switching the router off again for a full 30 minutes and then retest to see if there is any improvement in throughput speeds.
Message 6 of 12
Hi Debbie,
Just checked and I'm seeing 22.3 down and 9.2 up which is a big improvement on previous numbers but still not up to 39 down which was quoted in my sign-up documentation. Incidentally, the Hub dashboard shows 40 up and 10 down.
Looking good at the moment, thanks for your help thus far and hoping to get the 39 in time
Robert
Message 7 of 12
Hi Robert
Thank you, we should hopefully have further updates from BT Openreach.
Message 8 of 12
Hello Debbie,
Thanks for this and I'll post back tomorrow - it will be later in the day
Robert
Message 9 of 12
Hi Robert
Thank you, I can see that this fault has been raised and is under investigation with BT Openreach.
Please can you post back on this thread tomorrow morning and we can check for further updates on this fault.
Message 10 of 12
Hi Debbie,
I have updated my profile now
Robert
Message 11 of 12
Hi Robert
