Faster fibre 150 sync speed
3 REPLIES 3
alltalk20
Hi ! I had faster fibre 150 (gfast) installed on my line a few weeks back, everything seems fine just wondering if you could tell me my current sync speeds and max sync rate as well as how stable my connection is?
I can’t log into the open reach supplied modem to see these stats And I’m a bit geeky!
thanks a million 🙂
OCE_Chris
Hi alltalk20,
Your current sync speed is actually 160Mbps downstream and 18.3Mbps upstream
Authentication logs are showing only one reconnections since the 9th and that was on the 21st 🙂
alltalk20
Thanks for the quick reply, all very stable then which is good 🙂
OCE_Chris
Yes, all looks stable 🙂
