Faster fibre boost not working
GizF1
Message 10 of 10
I rejoined talk talk starting last week and it connected at 46.6mb which was about what I used to get with standard fibre before with my old supplier. I thought that maybe it would make sure it was stable then try again at a faster speed but no its just stuck at 46.6 and has been for 9 days now.
Please check it out for me
Giz
9 REPLIES 9
Message 1 of 10
Hi GizF1,
Ok thanks. If it does have a test socket then it would be worth testing the router at the test socket for at least 48hrs to see if DLM makes any changes to the sync speed.
Message 2 of 10
That's OK pretty quick actually for coming back on a Monday!
Think so, I'll have a look after work.
Giz
Message 3 of 10
Hi GizF1,
I'm sorry for the delay in getting back to you. I've run a test on the line which hasn't detected a fault. Does your master socket have a test socket?
Message 4 of 10
Hi Giz, that might be the best it can do!
Unfortunately we won't know until Monday when the team return to work.
Hang in there.
Message 5 of 10
Still 46.6 down 20 up
Giz
Message 6 of 10
Email notifications + nothing better to do
OK I'll give that a try
Giz
Message 7 of 10
Hey that was quick😁 So the speed is within guarantee but at the wrong end of expectation.
I would try a 30 minute reboot switch of, chill for 30 minutes then restart the router, this can cause DLM to reset. Don't do it repeatedly as the speeds will likely drop.
Message 8 of 10
Guaranteed 44
Download 49 to 72
Upload 14 (It's actually 20)
Giz
Divsec
Message 9 of 10
Hi Giz welcome to the community, what speeds were you promised when you opened your Talktalk account?
