Fault on Line
Jackie2012
Enlightened One
Message 11 of 11
We currently have a fault on our line, We have ran the service checker via our online account and its says '
We've detected an issue with your broadband
But we need your help to fix it. Let’s talk about it via Live Chat. '
Also our fibre service has been very unstable.
Thank you
- Everyday Is a good day to be alive, Whether the sun's shining or not! -
10 REPLIES 10
Message 1 of 11
Hi Jackie
Our Network Team have been unable to detect any faults on the line following their testing.
If all testing been completed with a different phone at the test socket then the next step will be to arrange a BT Openreach engineer visit.
Message 2 of 11
Hi Jackie
I've escalated this fault over to our Network Team and I will post back on this thread as soon as I receive further information.
Message 3 of 11
Yes that's correct, I've tried everything possible my side, things just haven't been right since our phone line went completely dead a while ago.
Message 4 of 11
Hi Jackie
Have you also tested with the router removed from the line? I can then escalate this fault over to our Network Team for investigation.
Message 5 of 11
every time I'm on the phone, The house phone is a corded.
Message 6 of 11
Hi Jackie
How often is the voice fault present? Does this occur if you test with a corded handset at the test socket?
Message 7 of 11
The other person can't hear me on the phone but I can hear them, Sometimes they can't hear me also.
we have just had this fixed by BT Openreach has we had no phone dial tone at all, They repaired a fault at the exchange or cabinet, however I'm still facing issue with the service
Message 8 of 11
Line tests are clear and the current sync speed of the router is within the estimated range for your line.  I'm also not seeing any retrains (drops).
Are you using wired or WiFi when you see a drop in the connection?
Can you check the home phone, is the line clear of any noise or crackling ?
Message 9 of 11
Can you re-check my line please, Our internet has been disconnecting a lot recently, I’ve ran the service status on my line and it’s saying my speed is lower than the speed we signed up for?
Thank you
Message 10 of 11
All line tests are currently clear and no issues detected.
Are you using a wired or wireless connection ?
Are all devices affected or only some ?
Can you check the Home phone and see if there is a clear dial tone or any noise on the line?
