Few of the devices keeps loosing connection however they are connected
sumit_sandhir
Message 3 of 3
I have installed Talk Talk wifi 3 weeks ago. FOr some reason in last few days my mobiles laptops keeps loosing internect connection. Wierd thing is they are connected with wifi but when I browse internet it says no connection. However my ring alarma system and my Tv have full internet access. Not sure what is going on. I also checked router settings they looks good and connected all the tome even though few of my devices has issues. The only workaround i found for now is to restart the hub.
Anyone has any clues why is it happening?
many Thanks
Message 1 of 3
Hi sumit_sandhir
Please can you update your Community Profile to include your name and TalkTalk landline number, we can then look into this further.
Skynet_TX
Message 2 of 3
Hi @sumit_sandhir,
Does this issue affect any devices that are connected wired, or is it just wireless devices that are losing connection.
What make / model of router do you have. If you have the Sagemcom Wi-Fi Hub, and the LED remains white when you have these issues then it is possible you are being affected by a known issues that affects the routers DNS, however if only wireless devices are affected then it could also be possible that you are suffering from Wi-Fi interference.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
