Fiber speed boost not working
Whybother
Message 38 of 38
Hi, I renewed my package on 29th Jan and noticed my speed boost wasn't included. Anyway after lots of calls to customer 'services' and an engineer visit it was finally decided that they hadn't enabled the boost. It should of been enabled on 8th March & I can see speed boost mentioned in my account now but im not seeing a real increase in speed over last package (38Mb).
My line speed on the router is now showing 50Mb down & 17Mb up. On the talk talk  speed test im getting 45M down &12M up ish. (over Ethernet) Ive done the 30+ minutes router switch off twice now and would like to see more speed, shouldn't the link speed be around 80Mb?
Anyway looking for some help now.
Cheers
Mark.
37 REPLIES 37
Message 1 of 38
Come on now this is really taking the P.
Message 2 of 38
Anyone?
I get a good speed for a 50mb connection but as im paying for a 70mb connection its really not on!
Hope to hear from someone soon.
Mark.
Message 3 of 38
Can we start moving forwards with this issue now please.
Message 4 of 38
Unfortunately as stated above, we can't arrange engineer visits for speed issues at the moment due to the lock down, apologies for any inconvenience.
Message 5 of 38
There was no confusion.
Arrange an engineer visit for me please.
Message 6 of 38
Hi Mark,
Apologies for the confusion, at the moment we are only arranging appointed engineer visits for total loss of service faults at the moment.
We can raise this for an engineer visit once the lock down is over and we have more engineer availability to the property.
Message 7 of 38
Yes arrange an Engineer visit please.
Here are todays tests
Router:
Mark.
Message 8 of 38
Hi Hasan77,
I'm sorry to hear this. Please can you create your own thread and we can look into this further for you.
Message 9 of 38
Hi Mark,
Unfortunately we can't arrange engineer visits for speed faults at the moment as we are only arranging home visits for total loss of service faults for vulnerable customers. We can raise this for an engineer visit once the lock down is over and we have more engineer availability to the property.
Message 10 of 38
I have the same problem!
Response time (latency)
13 ms
Download speed
33.4 Mbps
Upload speed
10.9 Mbps
Message 11 of 38
Here are todays results
Speed test: 46Mb, 10Mb
Router Stats: 49Mb 18Mb
Would be nice if an engineer could check the line for me.
Mark.
Message 12 of 38
Hi Whybother,
Thanks for trying this and I'm sorry to hear that there has been no further improvement in speed. As the speed is within the predicted range for the line then an engineer may not be able to increase this any further. Are you experiencing any issues with the overall performance of the connection?
If the line was syncing slightly better with the previous router then it would be worth swapping this back over again.
Message 13 of 38
New router test, still only the router plugged into the master socket, no house wiring involved.
Speed test 40.2Mb, 10Mb
Router link speed 49Mb, 18Mb
So its worse than before.
Mark.
Message 14 of 38
Hi Mark,
Thanks for the update. How are you getting on?
Message 15 of 38
last test with the original router on 20/3/20
Link speed 57.7Mb, 16.5Mb
Speed test 46.6Mb, 10Mb
So no change there.
Im going to set up the new router now.
Cheers
Mark.
Message 16 of 38
Hi Whybother,
Ok thank you for the update and please let us know how the speed compares with the replacement router.
Message 17 of 38
Still with the original router, here are todays tests.
Link speed : 57.7 & 16.5
Speed test : 46.4Mb & 15.7Mb
Ill let you know when the 2nd router arrives and do a test a couple of minutes after switching it on.
Message 18 of 38
Hi Whybother
Let us know how the connection/speed compares with this router.
Message 19 of 38
you can if you like but I doubt its the issue.
Message 20 of 38
Hi Whybother
I can send a replacement router for testing, would you like me to arrange this?
