Fibre 150 g fast modem
M18typ
Message 3 of 3
Hi, just had the fibre 150 installed yesterday but my speeds have been all over the place anything from 30-110, we run a WiFi booster upstairs but the engineer said that this could slow speeds as it runs the WiFi through the electricity cables, so did try without, the modem he installed he said will have 4 solid green lights but having just checked the power and DSL lights are solid green, there is no light for Internet and the LAN light is constant flashing green, do I have an issue with the modem
Matthew Phillips
Message 1 of 3
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
What make/model of both TalkTalk router & WiFi booster do you have?
Do you have any wired connections & if so, how do they perform?
