Fibre 150 keeps dropping
nexxusone
Whizz Kid
Message 29 of 29
had fibre 150 G.Fast upgrade a few months back took 3 visits by BT to get stable line ( they replaced everything form junction box on side of house, new wiring and new master socket ) at same time they re cabled our cabinet and estate.... and 5 houses down, road was dug up and repaired or replaced cables!!! this was 4 weeks ago and all WAS fine until a week or so ago. NOW we are getting re sync or restart on the G.fast modem - at random but worse from 2pm onwards.... of course when working a live connection test says line is fine... Can someone raise a test and or BT openreach engineer - I'm am NOT spending 4 hours+  to and idiot reading a script to be told again (like last time) to phone BT myself...
28 REPLIES 28
Message 21 of 29
Message 22 of 29
yes thats ok - will do
Message 23 of 29
Apologies, this may have been when I tested the line. Would it be possible to monitor the stability over the weekend to see how the stability compares?
Message 24 of 29
went down again at 8.20 am so unless you disconnected me to test still faulty
Message 25 of 29
I've checked the fault again now and there is an update to advise that Openreach have resolved a possible fault. I've also re-run the line test which is now clear. How is your connection at the moment?
Message 26 of 29
Thanks for the update. I've checked the fault, however there are no additional updates as yet. I'll check this again in the morning to see if there are any further updates back.
Message 27 of 29
well...... we lost internet connection at 12.02pm and it came back at 12.30pm - had no contact from BT, but hope this disconnection was the line being fixed. so will just wait and see if it occurs again or is fixed, as when line works it is good-  but use to drop and reconnect, this could be as little as a twenty second cycle. Hopefully fixed - time will tell.
Message 28 of 29
I'm really sorry to hear this and I'll take a look now. I've run a test on the line which has detected a possible line fault so I've passed this over to Openreach now for an external line investigation to be completed. if you don't hear anymore within the next 48hrs then please let us know and we can re-check for an update for you.
