Fibre 150 - perfomance not what was promised
timple
Message 17 of 17
Hi all,
I was on Fibre 65 and getting a great service - 60 down 20 up - no complaints. Talktalk then phoned me up and offered an upgrade to Fibre 150 on a special offer. Why not I think? Openreach engineer came last week (25th Aug) and installed the G-fast face plate and added a modem. He warned me that it would take a few days to get to optimum.....
But now my Chromebook is telling me that I am getting only 70 down sometimes - sometimes 50 - and only 15 up.  So basically at the moment I am feeling it wasn't worth it and I should go back to the old tariff.
Any advice?
16 REPLIES 16
Message 1 of 17
Hi timple
If the fault is found to be with Openreach equipment or due to the installation of the equipment then no engineer charges should be applied.
timple
Message 2 of 17
Speed to the router seems to have stopped working. https://www.talktalk.co.uk/help/servicestatus/speed-to-router
Is this just me?
My biggest beef is with reliability - it seems to be cutting out all the time. Screenshot 2021-12-13 121554.png
As long as my boxes are correctly installed - I won't be charged?
Message 3 of 17
I've re-run the line test now which hasn't detected a fault. Would you like to go ahead with an engineer visit?
timple
Message 4 of 17
Circular - tried the phone line - directed me to a test - sms back all fine. It isn't though.....
Message 5 of 17
Hi timple,
Thanks for answering the security questions, if you'd like us to arrange an engineer visit
The next step will be to arrange an engineer visit to investigate further, to do this can you confirm:
Message 6 of 17
Hi timple,
Thanks for answering the security questions, I've sent you a PM requesting a little more information
Message 7 of 17
I replied - what happens now - I am still not getting promised speeds. Check as below.
Message 8 of 17
Hi timple,
Message 9 of 17
Ok thanks - I replied
Message 10 of 17
Hi timple
I'm just sending you a Private Message to confirm some details so we can arrange the engineer visit.
Message 11 of 17
No changes to the installation since the 25th Aug! How do I arrange the visit?
Message 12 of 17
Hi timple
Thank you for updating your Community Profile.
I've completed a line test which has detected a potential fault towards the property and Openreach are requesting that we arrange an engineer visit.
Have any changes been made to your setup since your installation?
Message 13 of 17
Ok will do so - is the standard talktalk speed test recommended?
Message 14 of 17
thanks - have done so.
Message 15 of 17
Hi timple
Please can you add your name and TalkTalk landline number to your Community Profile. I can then check the sync speed.
Message 16 of 17
Please can you connect a pc via a wired connection to the router's port on the modem, in place of the router? Then do a speed test & that will tell you how fast the speeds are coming into the property. Then the problem can be dealt with from there.
