on 08-04-2022 10:08 PM
Hi There,
In June 2020 I signed up for a 18 month faster fibre deal with TT, the deal came to an end in January of this year and I switched to a 24 month Fibre 35 contract.
On the 18 month faster fibre contract I had no issue with my internet at all and everything worked well, since switching to the fibre 35 deal I have had some issues, the download speeds I am getting are quite poor and NOW tv is almost unwatchable, the picture will be great for a minute or two and then it will go quite blurry and hard to make anything out clearly.
I have included a screenshot below which shows my latest speed test on the TT website, does anyone have any ideas / solutions on how to improve this?
Jeanette
on 23-05-2022 07:46 AM
Please let us know how you get on 🙂
on 22-05-2022 08:53 PM
Thanks Keith,
Have changed the channel to number 11, hopefully that solves the issue.
Thanks for your help.
Jeanette
on 22-05-2022 01:06 PM
Thanks for all of your screenshots.
In the 2.4GHz band, you should only ever use channels 1, 6 or 11 as they are classed as the only non-overlapping channels. You are currently on channel 8, please move that to channel 11 (please see my guide for instructions on how to do that).
If the problem still persists, please can you get me a new set of screenshots having moved to channel 11?
on 16-05-2022 08:04 AM
on 15-05-2022 09:51 PM
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed in), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so that I can find it easily.
on 15-05-2022 07:05 PM
Hi Keith,
The router I am using is the TalkTalk WiFi Hub Black and have been using that since January this year.
Before January this year i had the other Wifi Hub the one with the goldish background and i had no issues what so ever with that router, it is only since i renewed my contract and was provided with another router that the issues began.
Jeanette
on 09-05-2022 09:41 AM
@Michelle-TalkTalk has asked me to help you with your wireless speeds.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
on 09-05-2022 08:05 AM
Thanks for the update. @KeithFrench - would you be able to offer some advice in regards to the varying wireless speeds please?
on 07-05-2022 05:49 PM
Hi Michelle,
I have just done some speed tests both wireless and wired and the wireless speeds have dropped quite a bit, since I turned my router off for 30 minutes a week or so ago and the speed improved it only seems to last for about 1.5 weeks at the most before dropping low, the wired test results are still high though. Really not sure what is causing this issue but the only way to sort it seems to be by turning my router off for 30 minutes every 1 / 2 weeks.
The wireless tests are above and the wired tests below
on 27-04-2022 07:20 AM
Thanks for the update. Would it be possible to run a few more wired speed tests over the next few days so we can see if the speeds drop?
on 26-04-2022 10:59 PM
Hi Debbie,
I have just done a wireless and wired test with my laptop, the wireless test results are below and the wired tests are at the very bottom
The wireless test results are above and the wired test results below
Both of the results are looking good but the speed never seems to stay that high.
Jeanette
on 25-04-2022 09:56 AM
Hi Jeanette2020
Would it be possible to run a wired speed test?
on 23-04-2022 11:51 AM
Can you try some wired - directly, not via PLAs - tests for comparison?
on 22-04-2022 11:51 PM
Hi Michelle,
The speed test was completed wireless via my laptop.
I have powered down the router for over 30 minutes and just done 2 speed tests, which don't seem to have solved the issue.
on 20-04-2022 08:08 AM
I've run a test on the line now which hasn't detected a fault and the sync speed looks ok. Was this speed test completed wired or wireless? Could you try powering down the router for a full 30 minutes and then run another speed test please as this will reset the current session and can often increase the throughput speed.
on 19-04-2022 11:21 PM
Thanks Keith
on 19-04-2022 09:52 PM
I'll ask TalkTalk support on this forum to investigate, as it is nothing that I will be able to help with.
on 19-04-2022 09:36 PM
Hi Keith,
Sorry for the delayed response.
The only real issue I have is with the NOW tv app on my Youveiw box, the other aps on the Yoview box such as BBC Iplayer etc all seem to work fine.
A week or so ago i turned the router fully off at the plug and left it for half an hour or so to clear the existing session and when i started the router back up NOW tv was working very well but that only lasted a week or so and the issue has now returned.
The Youview box is connected to the internet via Powerline adapters.
I have just done back to back internet speed tests on my laptop and getting varying results although neither if the results are particularly good
Jeanette
on 09-04-2022 11:18 AM
Hi @Jeanette2020,
@Gliwmaeden2 has asked me to help you. If you can please answer her questions about the way your devices connect to the router, then hopefully I will be able to help you.
08-04-2022 11:00 PM - edited 08-04-2022 11:01 PM
If your speeds to the device are poor, but speed to router is good, @Jeanette2020, it could be a problem with wifi congestion.
That's unless the device is wired.
Could you clarify?
@KeithFrench is particularly knowledgeable about such issues.
He may be able to help you over the weekend. Staff will not be back on here before Monday.
Help is also available via Chat from 9am:
https://community.talktalk.co.uk/t5/Articles/Ways-of-contacting-us/ta-p/2230529
Phone support is available from 9am on Saturday but not Sunday.
