Fibre 35 upgrade but no internet
3 REPLIES 3
chrisp58
Just upgraded on 2/3/21 but still have no internet connection, TT test shows an issue at home? tried resets not worked, router (technicolor TG588v V2) upgraded at midnight.
It’s connected via a filter directly to socket with no additional phone connection. Everything else Wifi etc is showing a green light, internet connects for a second or two and then disconnects.
Additonal info, i’ve gone into my Router internet access PPP connection window and it shows internet username is start@tentel.co.uk, is this still valid for fibre ? as i know TT took over Tentel and it worked before.
Any other solutions to help fix this ?
Skynet_TX
Hi @chrisp58,
TalkTalk fibre connections do not use the username and password in the router as the authentication is done based on the connection in the street cabinet.
Do you have a landline phone you can use to check if the phone line is working, if so does dialling 17070 read back your correct phone number ?
Then they will hopefully be able to respond to this post within a working day or two. You may get faster support from the live chat or by phoning up during opening hours.
chrisp58
Turns out my old Technicolor router is faulty so a new one is being delivered today hopefully that will solve the issue 🤞
OCE_Debbie
Hi chrisp58
Sorry for the delay.
How are you getting on?
