Fibre 35 upgrade
jre77
Message 11 of 11
Hi there,
I’ve got a fibre upgrade happening on Thursday 12th. I’m away for a few days at the moment but my third party router is on. Is that going to be enough to be able to activate the service? It’s an upgrade from Fast Broadband.
Many thanks,
John.
10 REPLIES 10
Message 1 of 11
Try a wifi channel change and see if this helps.
jre77
Message 2 of 11
Ah, ok cheers. I have a third-party router (TP-Link Archer 2100) as I had issues with both models of TalkTalk router. To be fair it's mostly very fast it's just occasionally it'll slow right down for a minute or so. I guess it could be interference.
Message 3 of 11
No, that's your router. Which TalkTalk model do you have and can you test with that?
jre77
Message 4 of 11
Everything seems fine with the Fibre 35 upgrade. The connection appears to be a lot more stable. I get a consistent 39 Mbps to the router but I've noticed the speed to the devices seems to fluctuate. One minute it's quite poor, the next minute it's brilliant. Is this all part of the line stabilisation process?
Message 5 of 11
No Problem 🙂
jre77
Message 6 of 11
Cheers Karl. I’m away at the moment so I’ll sort it out when I get home. The router is VDSL compatible so should be fine. Thanks for checking that for me.
Message 7 of 11
The fibre provide order was completed around 8pm last night, so fibre should now be live.
If you are using your own router currently, is this compatible with VDSL?  If it is, log into the router and check the connection type is set to auto or VDSL and not adsl.
jre77
Message 8 of 11
I’ve had nothing back from Openreach to say the upgrade has been successful. The texts I got in the run up to yesterday said they’d contact me when the work was completed.
In my account it says my package is now Fibre 35 but a line test says there’s an issue although its just that I’m offline and I suspect it could be because I have a third party router and it won’t be set up for Fibre at the moment.
Bit concerned that I’m going to come home from holiday to issues. Can someone look into this for me to see if the line work was completed?
Many thanks,
John.
Message 9 of 11
Please let us know how you get on and if you need any assistance 🙂
AllyM
Insightful One
Message 10 of 11
All that should be required is that an Openreach engineer will have to connect up your line from the PCP cabinet to the Fibre cabinet, so you shouldn't need to be at home.
