Fibre 65 (including Supersafe)
PFWLB
Message 5 of 5
I upgraded my TalkTalk package to Fibre 65 on 03/06/2021 (including Supersafe at an extra cost).
I was given a "go live" date of 04/06/2021.
So far, nothing has happened.
I have just spent one-and-a half hours "chatting" to five different agents - and answering a vast number of security questions, many repeated within the same conversations - only to be told, eventually, that nothing will happen until 07/06/2021.
In the meantime, I am left without any security on my computer.
Am I right in thinking there's a 20 days cooling-off period?
4 REPLIES 4
Message 1 of 5
I agree on some occasions I’m one of the first to spit my dummy out but on this one even I would give it a few more days before I went on one
AllyM
Message 2 of 5
I'm a bit puzzled why you would want to cancel the upgrade. It's only a couple more days to wait and if you cancel you're just back to where you are right now, unless I'm missing something.
bigkenny
Enlightened One
Message 3 of 5
unless your looking here there and everywhere and downloading anything and everything you will be quite safe with normal windows security switched on. Just dont open any emails/links unless your sure its from normal everyday web sites. Even with security add ons its best still to follow these simple rules if you do, you will be OK
Message 4 of 5
There is. What did you upgrade from?
