on 26-04-2022 02:45 PM
I upgraded from fast fibre to Fibre 65 last year and was never happy with the speed it was providing , around 37mbps when I was getting around 35mbps on the fast fibre contract. An OpenReach engineer tested the line and told me that was the best i was going to get so i had to accept that. Over the last 6 to 8 weeks the speed has been gradually dropping and now i am getting 27.46 mbps download . When I took out the contract it stated that I will be receiving a speed between 35 to 55 MBPS. Reading through other customers complaints on this forum there appears to be a problem with the speeds being capped if there is a fault on the LINE and I was wondering if this could be the problem in my case. My relative who is on the same Fibre 65 lives 10 doors away receives a download speed of 56mbps. That is from the telegraph pole before my one. I also have a problem with my broadband cutting out for a minute or two and then coming back on, this happens sometimes twice a day at various times. I hope I can get some help from this forum
on 07-06-2022 11:13 AM
on 07-06-2022 10:59 AM
Hi Arne , thanks for your fast response, much appreciated
Dodge08
on 07-06-2022 10:23 AM
Hi @Dodge08
A credit has been raised to clear the charge.
you will see it in the transaction history in My Account.
on 06-06-2022 11:15 AM
I had my last engineer visit booked for May 17th. The engineer informed me he couldn’t come until May 18th as the cherry picker was unavailable to check the top of the telegraph pole. He informed me that there were corroded connections at the top of the pole which he would clean up. It did not make much improvement to the speed . I told the engineer that the minimum connection speed guaranteed on my account is 39Mbps and he told me that I would not be able to reach this speed, the maximum I was going to get was 36Mbps at the pole , no internal work was done on the property. I had to accept that I was not going to get any better to reach your stated guaranteed 39Mbps so I am still paying for something that I was never going to receive. To make matters worse I received my monthly bill this morning with a £65 engineer visit added. There was no fault internally, just the corroded connections at the top of the telegraph pole which didn’t improve the speed but appears to have cured the cutting out problem. So I would like the £65 engineer charge removed please as there was no fault on my side, it was on Open Reach’s side, no work was done on my property.
Dodge08
on 04-05-2022 06:45 AM
Great thank you.
on 03-05-2022 04:14 PM
Hi Chris
Thanks for booking engineer. Will let you know how we get on.
Dodge08
on 03-05-2022 02:22 PM
Hi Dodge08,
I've booked the engineer for tomorrow afternoon - May 04 2022, PM (13:00-18:00) - please let us know how you get on
on 03-05-2022 11:43 AM
Hi Dodge08,
Thanks for answering the security questions. I've sent you a PM requesting a little more information
on 02-05-2022 10:24 AM
Hi Dodge08
In regards to potential engineer charges, if the fault is found to be with your own equipment or internal wiring then engineer charges can be applied.
Engineer charges - TalkTalk Help & Support
on 02-05-2022 10:17 AM
Hi Debbie
if you think an engineer visit is the next step please go ahead and arrange it. I assume I will not be charged for this visit , is that correct ?
Thanks Dodge 08
on 02-05-2022 10:05 AM
Hi Dodge08
Apologies for this.
If the connection is still dropping with a different router at the test socket then the next step will be an Openreach engineer visit.
Would you like me to arrange this visit?
on 02-05-2022 09:58 AM
Hi Debbie
The router connection is still dropping, it hasn’t been rebooted at any time, still only getting 27.8 Mbps on speed test
on 02-05-2022 07:54 AM
Hi Dodge08
I've checked the connection stats again and your line is in sync at 31.5mb and I can see re connections on the line.
Is the connection still dropping or has the router been rebooted?
on 28-04-2022 10:17 AM
Hi Dodge08
Thank you. We will check the connection stats/speed again in 48hrs to see if changes have been made by DLM.
on 28-04-2022 10:16 AM
Hi Debbie
Router now plugged in test socket since 9.45AM
on 28-04-2022 07:05 AM
Hi Dodge08
Would it be ok to leave the router at the test socket for at least 48hrs to allow DLM time to monitor the connection and adjust the profile?
on 27-04-2022 05:16 PM
The crackling on the line isn’t permanent, it is only now and again , the low speed and the intermittent dropping out is the main issue, I’m getting a slower speed now than I was getting on Fibre 35
on 27-04-2022 04:51 PM
The speed would not change immediately, but if the fault was being caused by the faceplate / internal filter then by using the test socket that will bypass the fault, the Openreach Dynamic Line Management (DLM) system would start to increase your speeds if the fault has cleared, but it may take 3 or 4 days before it starts to do this.
Can you still hear noise on the phone if you connect it to the microfilter that is now in the test socket ?. If you can still hear noise, then ideally if you have access to a different landline telephone it would be good to try with that as well, just to eliminate the phone itself as being a possible cause.
on 27-04-2022 04:10 PM
Hi Chris
Thanks, I found the test socket , with the router and filter plugged straight into that the speed is still only 27.8 Mbps
on 27-04-2022 03:26 PM
Hi Dodge08,
The NTE5 mk4 has a test socket, if you remove the faceplate the test socket is underneath
